What is Code 37?............1999 2.0L SOHC
Code 37: Torque converter clutch solenoid circuit or park/neutral switch failure.
that has nothing to due with cooling. does your Neon just over heat or does it only do it sometimes? nd code 35 actually has to due with cooling cause its the fan relay is bad.
I think the fan is simply unplugged. I run normally at idle, but it overheats at speed, ans loses cooland , but does not leak, that I can see. No oil in water, or vice versa, no smoke from tailpipe. All coolant is gone after 30 minutes of driving.
ORIGINAL: racerx55
blown head gasket
blown head gasket
http://cgi.ebay.com/ebaymotors/COOLA...spagenameZWD1V
http://www.diynetwork.com/diy/ab_aut...276327,00.html
if it was just the fans it would onlyover heatat stop lights and such
Trending Topics
go to http://mnc.allelitehosting.com/forum...topic.php?t=28
Dodge forum on there site gives you the code numbers and tell you what they mean
its:
Torque converter clutch solenoid CKT or park/neutral switch failure
its:
