Oil in spark plug cavities
Old 10-23-2007 | 12:53 PM
jeepr's Avatar
jeepr
Default Oil in spark plug cavities
First gen Neon, 2.0 SOHC. There is oil accumulating (quite a bit) in the spark plug cavities. Is this a terminal sign that it's ready to go out to pasture, or something fairly simply to seal somewhere?
Old 10-23-2007 | 01:02 PM
estneon's Avatar
estneon
Default RE: Oil in spark plug cavities
replace the spark plug seals....to do that take the vavle cover off....get a gasket kit for the vavle cover....shove the vavle cover gastet on and the spark plug seals.....if you want paint the vavle cover while your there.....thats just the first step i would take
Old 10-23-2007 | 10:22 PM
hatchetman2590's Avatar
hatchetman2590
i replaced mine ut there is still oil in there
Old 10-23-2007 | 10:35 PM
das2123's Avatar
das2123
ORIGINAL: hatchetman2590
Are you positive the spark plug tube seals stayed in there? Sometimes they fall out when reinstalling the valve cover.
Old 10-23-2007 | 10:44 PM
hatchetman2590
yea 3 dats later i double checked them now even if they did fall off i accidentaly broke one of the bolt head off so now i have to find a way to get it off
Old 10-23-2007 | 10:50 PM
das2123's Avatar
das2123
Easy out....
http://www.brokentap.com/easy-outs.html
Quick Reply: Oil in spark plug cavities
