update
......i do not recomend installinga srt-4 icon your car...omg it's alot of f-ing work
....i removed my a/c stuff too so i think thats why i think it's so bad...and the cutting of stuff to make it fit. i don't have any more cut off blades or good electric saws so i have to do it by hand[:@]it's close.....what type of bolts should i use to hold it up?
Seen a guy on the other forum who welded brakets made from just some stock 3/8' X probbaly around 1 1/2' steel to the radiator support in a rectangle shape and then bolted the ic to the brackets
well i got the ic on and the bumper will be on in the next day or two
...thanks for the advice 95to96...but its to late
and i don't have a welder so i would have to take it to a friends.
loli used some dykes (is that how it's spelled?) but they are shape so it was not that bad. i could not find my old tin snips so i had to do it thehard way...i also used a body workhammer to smooth out one area. and i wish i could afford a plasma cutter[8D].....new update : i got the bumper back on but the ic could be a little more down but it's fine...it looks crooked because i still need to adjust the bumper a little more butthe ic is on strait though
ORIGINAL: Aerorat
Most fun when they are bi
ORIGINAL: spudsterier
lesbians are alot of fun to have around
ORIGINAL: estneon
