Battery light flashing on and off, car jerks?
Old Nov 3, 2007 | 07:27 PM
pimpberetta's Avatar
pimpberetta
Default Battery light flashing on and off, car jerks?
My battery light will once and awhile, and more commonly now, come on every time I start the car. It will kind of jerk once in awhile when Im in 5th going down the highway.
What I've noticed, is that there is so much frequency when I rev the car above 1000 rpms, The radio no longer works and is just static. If I shut the engine off, but leave the radio on, the static is gone, even still going 100km/h.
I check the battery while running, little over 14 volts, battery is brand new last week, this all started actually after I put the battery in, and Im not sure if it could be related. Dumb thought, maybe.
If you have some insight on the problem, I would apprcieate some help, thank you.
Old Nov 3, 2007 | 08:24 PM
Aerorat's Avatar
Aerorat
Default RE: Battery light flashing on and off, car jerks?
Make sure the cables are tight and do not move on the battery
Old Nov 4, 2007 | 02:41 AM
iwalton63's Avatar
iwalton63
try cleaning your connections also.
Old Nov 4, 2007 | 10:07 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
batterylight will come on when engine turns off so it could also be a loose ground or connection at the alternator.
Old Nov 4, 2007 | 06:13 PM
pimpberetta
I cleaned the connections really well, still the same, I will look at the alternator connections next. Thank you.
Old Nov 5, 2007 | 10:24 PM
pimpberetta
Update.
It fells like the alt. is working sometimes, sometimes not, from the dim in the lights then goes bright.
I hooked my multi-meter up to a wire I ran to the battery, grounded the other in the car.
Read 12.50 volts off, 12.3-4 running, and after I went for a 5 min drive, the voltage never increased.
I check the connections off the alternator, they looked good.
Alternator sh@t the bed?
Old Nov 5, 2007 | 10:41 PM
95to96transplantneon's Avatar
you should be runing 13 to 14 while the car and alt. is charging. I think with my optima it was sitting at 13.43v when i thought my alt was going out.
Old Nov 7, 2007 | 01:16 AM
pimpberetta
Tore apart the alternator, looked ok, brushes were a little worn.
Cleaned them, "stretched" them out a tad then put it back together and is working good now.
Will be getting a rebuild kit this week, thanks all for your help!
P.S. Lowest price I foundm for a rebuild 3yr war. $230 w/ core! People are insane.
