View Poll Results: A poll
Voters: 4. You may not vote on this poll
crane 12, 14, 16 cams.
Old Nov 13, 2007 | 05:35 PM
justinsanders's Avatar
justinsanders
Default crane 12, 14, 16 cams.
as soon as my dad gets a car i will be putting a turbo on my car. (he drives mine to work and doesn't want me doing that to it while he's driving it.) i have enough money now for the turbo kit and cams. its a DOHC. i read that the 14's are specifically designed for turbo applications. but what will the 16's do that the 14's wont? and also will the car sound like its running rough at idle? cuz i like the sound of that. be sure to explain your answer. thanks.
Old Nov 14, 2007 | 12:23 AM
spudsterier's Avatar
spudsterier
Default RE: crane 12, 14, 16 cams.
10's would be about pointless to get...12's arent that aggressive......14's would be the best for turbo.....16's are a bit more harsh for a turbo, better for a N/A
Old Nov 14, 2007 | 11:25 AM
hnda8r's Avatar
hnda8r
ORIGINAL: spudsterier
[sm=exactly.gif]
Old Nov 14, 2007 | 11:42 AM
das2123's Avatar
das2123
You want the Crane #14 because of the split duration that it has. The exhaust duration is less which in turn helps spool the turbo quicker.
Old Nov 14, 2007 | 03:20 PM
justinsanders
ok thanks everyone. is there any modification needed to make them work? also how hard is it to do? do you have to retime it?
Old Nov 14, 2007 | 03:30 PM
das2123's Avatar
das2123
You will need upgraded springs to go along with the cams. You will have to reset the timing when you replace the cams anyway. Might be a good time to change the timing belt, wate pump and idler pulley as well.
Old Nov 14, 2007 | 04:24 PM
spudsterier
preferably get some springs and titanium retainers
Old Nov 14, 2007 | 07:14 PM
HabitatHxC's Avatar
HabitatHxC
get 22s
Old Nov 14, 2007 | 11:11 PM
spudsterier
screw 22's.....get some 24's
im just playin, i know you ment cams.......though 22's would be horrible for a turbo[&:]
[IMG]local://upfiles/29901/86E5A0F9A08C47B69347D9CD1741303B.jpg[/IMG]
Old Nov 15, 2007 | 05:56 AM
HabitatHxC's Avatar
HabitatHxC
lol i was wondering if someone would chime in with the rims dillio =P
