eibach springs
Old 11-15-2007, 04:02 AM
12 volt's Avatar
12 volt
12 volt is offline
Default RE: eibach springs
ORIGINAL: reaperof_evil
well this will sum it up it rides way better then the stock struts i had on sits just how i wanted it to handles like a dream but i have one question the struts off an r/t are they anything different from normal neon struts and how hard is it to swap the rear disks from a r/t i can the everything off the r/t for free how much will it cost to do will they bolt right up???
Lookes good........ i guess thows would be the Eibach Pro kit
rear disc
https://dodgeforum.com/m_725236/tm.htm
https://dodgeforum.com/m_682777/tm.htm
Old 11-15-2007, 08:21 AM
das2123's Avatar
das2123
das2123 is offline
The R/T struts are slighter stiffer than the regular ones in the front.
Old 11-15-2007, 10:43 AM
reaperof_evil's Avatar
reaperof_evil
reaperof_evil is offline
yeah 223 bucks brand new they are the pro kit on r/t struts im very impressed in how well it rides
Old 11-15-2007, 10:44 AM
reaperof_evil
so with the rear disks just take the whole hub assembly i can get for free and the disks and rotors
Old 11-15-2007, 10:48 AM
das2123's Avatar
das2123
das2123 is offline
You need everything from the e-brake cables all the way back.
Old 11-15-2007, 02:05 PM
reaperof_evil
ok well the r/t in the yard has everything i will have to buy new brake lines since they were cut but the only thing missing from the car is the motor sadly and trans and rims but i will be able to get all the stuff for free because i can just throw the stuff in my bag liek the mexicans do lol ill pay for the rotors so they dont search me lol 3n muchs a rotor and yeah ok so pretty much run the ebrake cables grab the knuckle and just bolt it up run all the lines and and it should be good ok so its alittle easier then i thought it would be if tehy are still on the car when i go back i will grab them and update if i need some help sincwe i dont have another car to drive and i dont have a garage lol so ill be doing it ibn the middle of the street like i do everything else thanks for all your help
Quick Reply: eibach springs
