window rattle
Old Nov 17, 2007 | 11:19 AM
crow01's Avatar
crow01
Default window rattle
Is there anything I can do for the window rattle that happens when the windows are down? It looks like the felt pads/guides are worn inside the door. This is the only thing I don't like about my car, not having the door frame the whole way around the window to hold it steady.
Old Nov 18, 2007 | 08:26 PM
Aerorat's Avatar
Aerorat
Default RE: window rattle
Glue padding back where it has worn away it is not that hard to do
Old Nov 19, 2007 | 01:26 AM
crow01's Avatar
crow01
What kind of padding, where would I get it, and do I stick it onto existing pad, or start from scratch? Anything is helpful.
Old Nov 19, 2007 | 01:35 AM
95to96transplantneon's Avatar
I used an old mouse pad... then used the rest to stop my wifes licence plate on her civic from ratlling.
Old Nov 19, 2007 | 10:42 PM
Aerorat's Avatar
Aerorat
I have used just foam padding and cut it down to the size i need and I also cleaned the track the best I could after pulling it out of the door
Old Nov 20, 2007 | 01:13 PM
tattoojack's Avatar
tattoojack
i had the same problem. i took off my door panel and found that the metal guide at the back edge of the window is cracked loose. it seems to hole the window steady when it is down but both are broken. this is why it rattles. either find some unbroken ones at the JY and maybe beef them up with some metal and a welder or try the pad idea.
