ITB's on 1st gen!!??
Old Nov 27, 2007 | 02:02 AM
  #31
mulletman11's Avatar
mulletman11
Default RE: ITB's on 1st gen!!??
ok well i dont want stacks and i need somethign over them to prevent getting dir/water in them. and def need them for a dohc, and detailed (ahah) instruction as to how to install them and i can prob do 800ish.
Old Nov 27, 2007 | 02:08 AM
  #32
95to96transplantneon's Avatar
do you want me tocallhim and let him know he comes on this forum every now and again so i can have him jump on and pm you if you like...
Old Nov 27, 2007 | 06:26 AM
  #33
estneon's Avatar
estneon
i was going to put itb's on my bonneville it's just to much work so i think i will just get them made
Old Nov 27, 2007 | 10:58 PM
  #34
mulletman11
honestly i would have to get out of debt, but around january, yes i would be highly intrested
Old Nov 28, 2007 | 12:55 AM
  #35
AMM's Avatar
AMM
ok im here now..............
anyways itb's are going to help u get the most out of an N/A car if ur going for peak hp numbers and depending on how long ur stacks are u can adjust that power some (thanks to arthur and all those dyno runs he did we now know this). the blue line are indeed vacuum lines that are tapped off of each runner between the throttle plates and the head so u can pull vacuum while while ur idling or off throttle to help with braking. u need this for ur brake booster and map sensor for sure and u can also throw ur IAT sensor in there also. unfortunantly this setup does not incorporate IAC so u need to let ur computer learn because there is enough air getting past each throttle plate in order to let it idle just fine. the gas pedal is very very touchy and the sound is amazing. there is no problem what so ever taking these things to the track with me, and throwing them on.............. it 10 mounting bolts and a few others and thats it. this particular setup is meant for the track so i also did not incorporate filters which is an easy fix............. go buy 4 individual filters. as for turboingit........... yeah ur gonna need to build a metal plenum around it (aluminum preferably) and then boost away just like a normal turbo set up......... tuning is gonna be a PITA though. anyways these things are awesome and i want to throw them on the dohc 2.4 that im gonna be building so i think i may just keep them.......... besides neon owners for the most part are cheap and are not going to want to pay 1k for them but i thought at least i would try.
AMM
Old Nov 28, 2007 | 02:20 AM
  #36
estneon's Avatar
estneon
not to take buinuss away from you amm(considering i always recomend you)...but you other guys you could make your own...in august i made some for a friends impala and it took three days[&:]but on a neon i could only see one day maby two (if you had the parts)
Old Nov 28, 2007 | 09:00 AM
  #37
AMM's Avatar
AMM
but odds are good it wouldnt look or flow as good as mine
Old Nov 28, 2007 | 12:27 PM
  #38
estneon's Avatar
estneon
true i doubt they could....out of curiousity...can they pass ourstupid az emissonshey would you sell them for $850hell i could walk over to your house and give you cash.
edit:i should add...im not broke or cheap (not even one partwas from ebay) like other neon owners. lol
Old Nov 28, 2007 | 01:44 PM
  #39
hnda8r's Avatar
hnda8r
Hey what the hell is that supposed to mean!!!![sm=icon_quiet.gif]
Im cheap and broke and still have a fast car.
Sorry I dont have enough money to get all the name brand stuff, you hurt my feelings
[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
Old Nov 28, 2007 | 02:34 PM
  #40
boxerjl2's Avatar
boxerjl2
i dont understand ok everyone says that just have a 60mm tb is bad but this is haveing 4 atx tbs how is that not to much air
in one instance prolly recently Spud said it woulod be like putting your head out the window it would just choke it out and lose performance so how how haveing 4 not do the samw thing???
