wiring problems
Old Dec 2, 2007 | 09:02 PM
hatchetman2590's Avatar
hatchetman2590
Default wiring problems
can anyone help me. my fuel pump fuse was blown and i replaced it and it keeps blowing wat do u think the problem is
Old Dec 2, 2007 | 10:49 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: wiring problems
Sounds like you have a wire shorted to ground. Start following toe wires from the fuel pump back along the frame and see if you can find the short.
Old Dec 3, 2007 | 07:05 PM
moparman73's Avatar
moparman73
it is probably your downstream O2 sensor wires grounding out, this is a common problem for neons since the O2 sensors are on the same circuit as the fuel pump fuse. mine had the same problem, i had 4 wires behind the engine melted together and grounding out blowing my fuse, i would follow the downstream O2 sensor wires and make sure they are good
Old Dec 3, 2007 | 07:09 PM
hatchetman2590
wolud taking the o2 sensor off hurt it?
Old Dec 3, 2007 | 07:13 PM
moparman73's Avatar
moparman73
im not too sure, but i know it will throw a code and your gas mileage will be bad.
Old Dec 3, 2007 | 08:46 PM
hatchetman2590
wat exactly do u mean by downstream o2 sensor is that the one behind the cat? also i traced all my wires out and no places to ground out wtf is wrong with my car
Old Dec 3, 2007 | 09:01 PM
95to96transplantneon's Avatar
Like they said its a grounded wire somewhere....you have to find it. it could be anywhere from the fuse panel back to the fuel pump and anything else that is on that circuit...thats alot of wire to go threw....sorry man.
woo whoooo 300 posts.
Old Dec 3, 2007 | 09:17 PM
hatchetman2590
yea i know im just going to take my dang car to my mechanic he has more time to work on cars than i do. but this really sux because i have **** to do and i cant do it from home. dang im so pissed
Old Dec 4, 2007 | 02:57 AM
12 volt's Avatar
12 volt
Ive heard of bad fuel pumps blowing fuses. you should try and swap a junkward pump in and see if it helps
Old Dec 4, 2007 | 07:09 AM
hatchetman2590
ok how hard is that to do
