2.4 swap
Old Dec 23, 2007 | 02:05 AM
  #21
boxerjl2's Avatar
boxerjl2
Default RE: 2.4 swap
so when i go to do the 100k tune up,, do i use 2.4 parts,, or do i use the 2.0 dohc parts.. timing belt,, water pump,, tensioners, and all that good stuff
Old Dec 23, 2007 | 02:08 AM
  #22
boxerjl2's Avatar
boxerjl2
are the 24 lbs injectors neccesarry.. whats wrong with the injector that are already on the 2.4??
i dont understand why i have to get all new parts
like the Dohc fuel Rail whats wrong with the one thats on the 2.4??
Old Dec 23, 2007 | 02:39 AM
  #23
95to96transplantneon's Avatar
ok the reason you need the 24lb injectores is this....
Yes the 2.4 uses the same injectors we have in our 2.0's rated at 19lb however the stratus pcm sends a fater or longer pulse width to the injector then our 2.0 pcm sends there for if you leave the 19lb 2.4 injectors in it will run lean.
You know I'm not quite sure why you have to use the 2.0 DOHC fuel rail all i know is that you have too... maybe different connectors.
Noone said you have to by new. just different parts... alot of it has to deal with that your putting a motor that wasent designed to fit into a neon in a neon and then running that motor with neon sensors and computer...and just to save you time, no you can not use the stratus computer. Wiring harness from the pcm to the cabin is compleatly and I mean compleatly different.
I'm not going to lie to you boxer It is a big job and there is alot of stuff to do to get the 2.4 to work, alot more then justswapping in a 2.0,however the payoff in the end is great....
Granted I've never done this swap before Josh but Dude I spend maybe 4-5 hours a day reading on here and mostly the .org.
I would not sugest you signing up with the org Hell I dont even post there just pm people when i want to buy there parts. The guys over there tear any and ALL newbee's up and throw them to the curb...You allways no matter what will get a "what now you want us to spoon feed you why dont you go and read and thensearch and then read it again and then come back after you have read everything you can find and then read again." everything that could possably be talked about has allready been said over there and there search button dont work worth a **** due to there being over 10 years worth of post. I have read and read and read, Just ask us honestly. I will guide you the best I can and if I dont know I will look it up I have alot of stuff in my fav. of there post that I can easly dig up...
SPUD you know its true they even have done it to you. I've seen it.
Old Dec 23, 2007 | 03:24 AM
  #24
Slashwannabe's Avatar
Slashwannabe
Here go teach Neon's.org a lesson and hack their *** j/k, here's their Servers IP: 209.115.183.2
and here's the rest of the info on the owner of the site...Modern Performance. Call em up and bitch and say their forum moderators are a bad reflection of their company.
Registrant:
Make this info private
Modern Performance Racing Products
9531 Townpark Dr
Houston, TX 77036
US
Domain Name: NEONS.ORG
Administrative Contact , Technical Contact :
info@modernperformance.com
9531 Townpark Dr
Houston, TX 77036
US
Phone: 713-270-8520
Record expires on 17-Jun-2009
Record created on 27-Jun-2002
Database last updated on 01-Aug-2005
Domain servers in listed order:
Manage DNS
NS1.WILDROSEWEB.NET
209.115.183.2
NS2.WILDROSEWEB.NET
209.115.183.3
IP Address:
204.209.35.170(ARIN & RIPE IP search)
IP Location:
CA(CANADA)-ALBERTA-EDMONTON
Record Type:
Domain Name
Server Type:
Indeterminate
Secure:
No
