Map clamp
Old Dec 12, 2007 | 05:21 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Map clamp
So let me get this straight. You dont need a map clamp for 95's, but 96-99 you do? What engine would i better of turboing?
Old Dec 12, 2007 | 07:35 PM
Slashwannabe's Avatar
Slashwannabe
Default RE: Map clamp
95 and 96-99are the same Engine with exception of Electrical hookups and a few other minor differences.
Old Dec 12, 2007 | 09:25 PM
I_Ride_Neon
For a turbo set up.
Old Dec 12, 2007 | 11:57 PM
95to96transplantneon's Avatar
Thats a good question, i know that after 95 they made 2 of the sensors into one. I would guess you wouldent be able to use the missing link, you would have to use the voltage clamp style on the 95.
Old Dec 13, 2007 | 07:04 AM
Slashwannabe
You can use the Missing Link on a 96-99 Engine.
Its a combined sensor, MAP (Manifold Absolute Pressure) and IAT (Intake Air Temp) Useing the missing link which is basically a check valve designed to work with the Map sensor wont affect the IAT fromsensing correct intaketemperature in the combined sensor design.
And on the 1995 you shouldn' have any problems as it fits under your current map sensor. The 95 intake has the same map plug in that the 96-99 have only difefrence is they combined them into one sensor and they put a block off in the manifold where the old IAT used to be.
You have your Choice of a either a map clamp or missing link. If you don't like wiring and soldering go with the missing link and if you like total adjustability of your air fuel ratio go with the map clamp. Installing the missing link is a 2 minute job installing the map clamp takes a little bit depending on your skills and patience stripping and cutting wires.
Old Dec 13, 2007 | 01:57 PM
I_Ride_Neon
Wow that cleared up alot thanks so much.
Old Dec 16, 2007 | 03:05 PM
I_Ride_Neon
So its correct to say that the intake manifolds arr different between a 95 and a 96? Where is best cheapest place to get missing link?
Old Dec 16, 2007 | 03:59 PM
I_Ride_Neon
http://www.racingworks.com/missinglink.htm it says you need to modify the map sensor for it to fit on the sohc? Can i just use the dohc sensor or something>?
Old Dec 16, 2007 | 04:28 PM
I_Ride_Neon
2 more things. 420a is the sohc right? and since mine is a 96 it has the map sensor integrated air temp sensor right?
Old Dec 16, 2007 | 05:54 PM
I_Ride_Neon
So i need to get the ML006C one right? or will 003b work with it?
http://www.nipponpower.com/product.phtml?p=235
