oil leak??
Old Dec 28, 2007 | 11:05 AM
blondiez24's Avatar
blondiez24
Default oil leak??
My sisters car started leaking oil so bad she couldn't even drive it. So her Dad started tearing in to stuff without knowing what he was doing. He said it is leaking by the thing the oil filter attaches to. Do any of you guys know what this would be? He took all the bolts out of it he said, and can't get it to come off. Help me out before he tears something up. What is something right there that could leak?
Old Dec 28, 2007 | 11:08 AM
spudsterier's Avatar
spudsterier
Default RE: oil leak??
in that location it could be the crank sensors, oil pump, cam seals, or even possibly, the last time on oil change was performed, the o-ring for the old filter might not have been removed
Old Dec 28, 2007 | 11:17 AM
blondiez24's Avatar
blondiez24
what would be the best way to find out which is leaking? For someone who doesn't know that much!
Old Dec 28, 2007 | 11:23 AM
uta_flyinghigh's Avatar
uta_flyinghigh
Pics would help.
UTA
Old Dec 28, 2007 | 11:50 AM
blondiez24's Avatar
blondiez24
ok got a little more info on the leak. He said it doesn't leak when the engine is running, but when you shut off the engine it leaks for about 20 minutes then stops again. You can actually see it dripping out pretty fast when you shut off the engine. Then it gets slower and then quits leaking.
