serous help needed!
Old Jan 8, 2008 | 11:05 PM
  #21
noenwarrior's Avatar
noenwarrior
Default RE: serous help needed!
thereya go i agree with that its a good start.
Old Jan 8, 2008 | 11:44 PM
  #22
95to96transplantneon's Avatar
instead of doing the emulator you can do the resiter trick...
You can try the resistor trick. This involves soldering a ¼ watt, 1megaohm[/b] resistor into the black wire of the downstream oxygen sensor. This will effectively fool the computer into thinking there is still a catalytic converter in place, by changing the output of the downstream oxygen sensor. The resistor trick will only work if you leave the downstream oxygen sensor in the exhaust piping. You cannot remove the downstream oxygen sensor from the exhaust piping, coil it up, and use the resistor trick; it does not work.People have tried to use the resistor trick without the downstream oxygen sensor in the exhaust pipe, it does not work that way. The downstream oxygen sensor MUST be in the exhaust pipe for the resistor trick to work.
Old Jan 9, 2008 | 01:47 AM
  #23
rayraydoet's Avatar
rayraydoet
its running lean not rich i ment to correct it i thought i posted that i ment its runing lean 19.9 is lean and 9 is rich i had it backwords. as now vi changed the fuel filter aqnd notice it got a little richer but it still running lean when i let off the pedel and when i cruze on the hiway. as for the resitor thing i can do that and use my plx r 500 witch has narrowband output and a resiter for the heater wires to fool the computer. and this emulator how does it work how u use it where do you get it?? and if i get afx it will get rid of that o2 and the egr code i got and the carb cansiter that i took out
Old Jan 9, 2008 | 02:15 AM
  #24
http://www.o2simulator.com/index.php...;products_id=9
heres one it has to be soldererd in... cant find the acuall mil plug everyone that used to sell it doesent anymore or i cant find it maybe someone else can...
Old Feb 7, 2008 | 04:06 PM
  #25
rayraydoet's Avatar
rayraydoet
hey what risistor should i use on the signal wire to make it look like that there is a sensor? i no for the 2 wires that go for the heater wires im guna put 20 ohm 10 watt resistor and
