Old Jan 11, 2008 | 03:44 PM
estneon's Avatar
estneon
Default ????????
i have questions
well i finally think the car is 100% perfect fuel psi wise but...
1. my boost gauge quit working...now i know to check all the lines...but i did and there is no problem...so any other tips? and yes it is boosting
2.where do you hook up a boost controller on a neon?...i hooked it up and all but it dose not do **** it just looks pretty and alows it to hit 5to something psi(gauge broke so i dont know)
3. something weird happedthe otherday when i did a quick powerslide...my car beeped(that warning beep) and the gas guage went to zero but came back up after a few seconds...wtf is that?
Old Jan 11, 2008 | 04:04 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: ????????
Did u check to make sure u did not have any part of the vacuum hose that may be rubbing or maybe cut..... i would check that, if not try blowing in the gauge with a small vacuum line hooked to it, to see if the needle is stuck..... ihad a friends car needle get stuck....
what kind of turbo u running? u run the boost controler off of ur waste gate.....
as for the car beeping, dont power slide jk, i am not really sure on that....
Old Jan 11, 2008 | 04:58 PM
estneon's Avatar
estneon
well with the boost gauge im confused... just took the car(yes illegally) out on pavement and it works and then it dosent work i cant stand it but it helped taking it out on longet roads im getting way over 120 psi with my fuel (at 5-7 psi)so i still need a hell of a lot of work.
all i know about it is it's a hahn 16g (im not realy into knowing muchabout small turbos) but yes i hooked it up between(fk it i'll get a pic)
Old Jan 11, 2008 | 05:22 PM
spudsterier's Avatar
spudsterier
did you remove your gauge cluster at any point???? maybe its just loose
Old Jan 11, 2008 | 05:34 PM
estneon's Avatar
estneon
it's finnaly working right idk what it was but it's happy so im happy.
Old Jan 12, 2008 | 12:16 AM
12 volt's Avatar
12 volt
gas sloshingaway form the fuel level transmitterto the other side of the tank.
Old Jan 12, 2008 | 01:00 AM
ryleynoyes's Avatar
ryleynoyes
120 psi on your fuel pressure? holy $#!t! what are you running injector wise and fpr rate wise (8:1 12:1?) and what is your idle fuel pressure set at?
Old Jan 12, 2008 | 04:20 PM
estneon's Avatar
estneon
idle psi is 43-58 i cant get it to stay at 45-55...i have stock injectors but thats just what the psi coming from the fpr (begi) so im sure the stock injectors where hurting a littlei had it down to about 100psi but the cars acting weird now so i cant retest it[&:]
Old Jan 12, 2008 | 06:40 PM
spudsterier
your fuel pressure should be at about 112-125psi while under 8-10 pounds of boost....
