car died
Old Jan 13, 2008 | 05:21 PM
fsu182's Avatar
fsu182
Default car died
car died at 4000 rpm in 4th gear while accelerating. the starter wont turn the crank. the car wont start with the ignition or drift starting it. there wasa slight bump just as it died while the rpms were rising. the starter spins (sounds like a vacuum cleaner or something) but doesnt turn the engine over..... anyone have any ideas?
Old Jan 13, 2008 | 05:43 PM
6sic6's Avatar
6sic6
Default RE: car died
didnt break a t-belt did you? got spark? fuel? compression?
Old Jan 13, 2008 | 08:03 PM
mr340's Avatar
mr340
Muscle Car Moderator
Will the motor spin at all if you try to push it and pop the clutch? If the starter won't turn the motor there is no way to check compression.
Old Jan 14, 2008 | 02:21 AM
fsu182's Avatar
fsu182
timing belt looks ok. the crank will turn if you drift the car and let it in gear, but the car must not have spark or ud think it would fire. ill have to check it out tomorrow. as for tonight my trip back to campus involved me riding shotgun in a 92 tracker with no exhaust that would only do 45 up the mountain to get here.... lol
Old Jan 14, 2008 | 03:41 AM
pssssst's Avatar
pssssst
dude i know this doesnt help your problem any, but i have noticed neons decide to die whenever they please for no logical reason at all mine has been dead for the last 6 months because isprayed under the hood,and thank god i have a leased car that is a dependable daily driver
Old Jan 14, 2008 | 12:26 PM
12 volt's Avatar
12 volt
the starter bendix isnt engaging into the flywheel because of a fualty solenonid.
http://www.carcare.org/Electrical/solenoid.shtml
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jan 14, 2008 | 02:28 PM
99 Neon's Avatar
99 Neon
maybe its those 218 thousand miles on your car. i had a manual that died out on me wit 184K but than again i got it at 163
but now she has about 66
Old Jan 14, 2008 | 03:25 PM
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: pssssst
+1!
Old Jan 15, 2008 | 10:15 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Let's get some back round on your neon. Have you done any work in the past few weeks, and possibly not put something back? Also, what codes are you getting? We have to keep in mind our neons are approaching the 10-15yr mark. As I explain as often as possible, buying a new car is not always the best decision. Put that money toward ALL new sensors, a new engine harness, tires, etc, and you have a new car all over again. My neon just stopped starting as well, and some common cause are failed cam sensor, crank position sensor, bad grounds, loose connections, timing belt skipped a tooth; those are most causes and there are more that give no codes. Stir the pot and see what comes up.
Old Jan 15, 2008 | 10:17 AM
Ghost Neon 2
[quote]ORIGINAL: Jr. Mechanic
ORIGINAL: pssssst
dude i know this doesnt help your problem any, but i have noticed neons decide to die whenever they please for no logical reason at all mine has been dead for the last 6 months because i sprayed under the hood, and thank god i have a leased car that I did not spray under the hood *FIXED*
+1!
Let's not blame the student, when the teacher is in charge, no?
