individual ignition coils
Old Jan 18, 2008 | 12:49 AM
neonracer1010's Avatar
neonracer1010
Default RE: individual ignition coils
ORIGINAL: Jr. Mechanic
This is a common misconception in the world of racing. Hot spark does not = HP. Sure it is great, but is only needed when you are turning extremely high rpms, then if you get too crazy, say by by to your pistons... You don't really need hotter spark with high compression if you think about it, the higher the compression the easier it tends to combust meaning it really requires less spark.
diesels run off of compression, they arent constantly getting spark
Old Jan 18, 2008 | 01:38 AM
pimpberetta's Avatar
pimpberetta
ORIGINAL: neonracer1010
What are you getting at?
Old Jan 18, 2008 | 01:45 AM
95to96transplantneon's Avatar
heres a pic of dcr's srt4 with individual ignition coils...
[IMG]local://upfiles/61619/736AF8FC3565478A90D05CBE6FEDDE7C.jpg[/IMG]
Old Jan 18, 2008 | 05:52 AM
12 volt's Avatar
12 volt
not exactly, the more cylinder pressure you have the harder it is for the spark to jump the electrodes.
easier it tends todetonate
heres a good link that talks about multiple spark ingnition. not the same as just having the coils but explains the diffrence between OEM and performance
http://www.msdignition.com/1helpmechoose.htm
Old Jan 19, 2008 | 06:10 PM
tranyinstaller's Avatar
tranyinstaller
Individual coil packs are used in major drag racing because at high compression it is NECESSARY to run hotter plugs. if you dont, the spark will actually get blown out! seriously, trust me i know what im talking about.
As to the reason they use individual coils, thats because heat disturbs electrical continuity. with electrical **** like that, the cooler it runs the better. sepperate the coils into individuals and each one gets a 3 rotation brake to cool down befor it has to fire again. so they can run more power and generate it without melting the coil.
So if ur running 30psi this would be a great idea!
if ur running n/a or just 10psi no point, really.
Well at least thats my take on the whole topic.
