individual ignition coils
Old Jan 17, 2008 | 07:04 PM
jfink's Avatar
jfink
Default individual ignition coils
while working i was wondering if it was possible to have individual ignition coils for each cylinder? I know it would have to be wired the same way(1&4,2&3). seems to me it would work and there would have to be some slight gain from it. any thoughts or opinions or would it just not work how i beleive it would.
Old Jan 17, 2008 | 08:29 PM
95to96transplantneon's Avatar
Default RE: individual ignition coils
I want to say it is possable the neoprezza guys have done it with i want to say wrx coil packs... but dont quote me I just know they have done it...
Old Jan 17, 2008 | 09:24 PM
jfink's Avatar
jfink
anyone know were i can get information about stock ignition coils
Old Jan 17, 2008 | 09:39 PM
71RoadRunner's Avatar
71RoadRunner
It is possible and has been done, but is pretty much useless unless your running extremely high compression, as in pro racing. If you check out Mchats most recentvideo of his SRT-4 you can see he is using a coil pack for each plug.
Old Jan 17, 2008 | 10:00 PM
jfink's Avatar
jfink
so there is no performance gains on a mild N/A 2.4
Old Jan 17, 2008 | 10:04 PM
not really... with higher compression you need more spark....
now that i think about it dcr makes them for the 2.4...however DCR = expensive as absoulute hell... like more then your car is worth expensive... not saying you have a cheap car but you would pay more then the KBB value for something like that...
Old Jan 17, 2008 | 10:29 PM
6sic6's Avatar
6sic6
Yea, your not going to notice a gain on the butt dyno butt if you really want them alot of neon guys use coil on plug set ups from chrysler 300c's.....
Old Jan 17, 2008 | 10:46 PM
jfink's Avatar
jfink
so do they use the whole set up or just the coils themselves??
Old Jan 17, 2008 | 11:11 PM
Jr. Mechanic's Avatar
Jr. Mechanic
This is a common misconception in the world of racing. Hot spark does not = HP. Sure it is great, but is only needed when you are turning extremely high rpms, then if you get too crazy, say by by to your pistons... You don't really need hotter spark with high compression if you think about it, the higher the compression the easier it tends to combust meaning it really requires less spark.
Old Jan 17, 2008 | 11:51 PM
jfink's Avatar
jfink
general concessus(can't spell it) is. rather pointless for performance, just for orginality
