Aftermarket valve springs
i have the serious street comp cam for my 98 neon ....i was wondering if anyone had any ideas as to wat vavle springs i should buy....id also like to know if anyone would know if there is a better cam suited for my application ...i race on a 1/3 mile oval track ...kinda small (never leave 2nd gear) some mods are they head is ported and polished , triple grind valve job, bored 30 over (75mm) venom injectors ...CAI..JET module..and im goin to be purchasing the af/x race computer soon after i figure this all out ...thank you for your time...
![](http://static.summitracing.com/global/images/prod/norm/jet-68005_m.jpg)
![](http://store.summitracing.com/global/images/1105/r_largeimage_btn.gif)
![](http://store.summitracing.com/global/images/1105/r_nav146_01.gif)
![](http://store.summitracing.com/global/images/1105/r_add_wishlist_btn.gif)
![](http://store.summitracing.com/global/images/1105/r_nav146_cart.gif)
![](http://store.summitracing.com/global/images/1105/r_compare_btn.gif)
![](http://store.summitracing.com/global/images/1105/r_wishlist_btn.gif)
![](http://store.summitracing.com/global/images/1105/r_nav146_03.gif)
Image is a representation of this part. Actual part may vary. JET-68004 $229.95
Estimated Ship Date:Today
![](http://store.summitracing.com/global/images/media/gl/images/nav_overview2.gif)
![](http://store.summitracing.com/global/images/media/gl/images/nav_bkg.gif)
![](http://store.summitracing.com/global/images/media/gl/images/nav_application.gif)
![](http://store.summitracing.com/global/images/media/gl/images/nav_warranty.gif)
![](http://store.summitracing.com/global/images/media/gl/images/nav_end.gif)
![](http://store.summitracing.com/global/images/media/gl/images/nav_showall.gif)
Using the same computer tuning popularized by JET's Stage 1 and Stage 2 computer modules/chips, these Power Control Units use a 20 MHz RISC microprocessor. This optimizes the ignition spark advance and recalibrates the fuel map for optimum horsepower and acceleration. Other features include an LED readout and an on/off override switch. [/align] Back to Search Results [/align]
ya i kno its a turbo grind ..but i talked to one of the tech guys at crane and thats the cam he suggested for my application..he said that because the exhaust valves would be shut longer i would build up more compression and id have more torque ...which is exactly wat i need for wat im doin with my neon ...like i said its a dirt track car ...i dont need to be able to run 100 mph ...all i need is to get from 0-60 faster than everyone else..because 60 is about all the faster we get goin on the small track i run ...do u think he is right about it or not ...check out the grinds and tell me wat ya think thank you
http://www.cranecams.com/?show=brows...umber=158-0012
