exhaust manifold
Old Dec 10, 2004 | 11:58 PM
nightstreetneon's Avatar
nightstreetneon
Default exhaust manifold
whats a good exhaust manifold for a 98 sohc.
Old Dec 11, 2004 | 01:58 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: exhaust manifold
Are you taling about header or manifold?
Because the stock manifold is pretty good ofr stock and there are quite a few headers for the Neon.
Old Dec 11, 2004 | 02:27 AM
nightstreetneon
i need a manifold for a turbo.
Old Dec 11, 2004 | 02:35 AM
Cr@zy Squ33
What type of turbo?
There are a few manifolds out there. I currently have a Chill Factory manifold.
Old Dec 12, 2004 | 05:39 PM
nightstreetneon
i think its a T23, from a stock eclipse. im not sure if thats the name tho
Old Dec 12, 2004 | 06:41 PM
Cr@zy Squ33
16B is whats on the eclipse. Thats also a very small turbo.
Old Dec 12, 2004 | 06:59 PM
nightstreetneon
well im only paying 400 for everthing except the manifold. is that worth that much. the guy said he ran low 14's on it. and he was stock.
Old Dec 12, 2004 | 07:18 PM
Cr@zy Squ33
I don't think its worth it because its a small turbo. Its going to build a lot of heat and you are going to have to do quite a bit of work to the car to handle it.
Perhaps you should look into a bigger turbo as you'd have to do less work with it.
Old Dec 12, 2004 | 07:20 PM
nightstreetneon
ok, thanks for the advice crazy. i wouldnt want to waste my money on it then. but just out of curioisity, what else would i have to do?
Old Dec 20, 2004 | 07:38 PM
Cr@zy Squ33
Theres quite a bit of things you are going to need to do.
Fuel System, piping, boost control the list oges on and on.
