need help with wiring?!!
Old Jan 25, 2008 | 01:51 PM
97wbody's Avatar
97wbody
Default need help with wiring?!!
ok i just finished my mtx swap but i dont have reverse lights everything else works... car turns on fine and runs good... and check engine is on too... p0115 which i think is the coolant temp sensor i got that one covered the other one is p0743 i think and i think thats the one for the converter solenoid? im not sure what to do on that one any help?
Old Jan 25, 2008 | 02:03 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: need help with wiring?!!
With any MTX swap you will need to wire to the reverse switch , unsure if you went from an auto to manual or manual to another...but likely you need to use the reverse switch to turn on the lights ...
Old Jan 26, 2008 | 12:45 AM
97wbody's Avatar
97wbody
i did atx to mtx.... the way i tried it first is i left the switch off the mtx on and spliced it to the atx connector and the third wire i just grounded it... the car started fine with no problem... but no reverse light... do i have to put the atx switch in place of the mtx switch and then ground off the third wire?any body
Old Jan 26, 2008 | 08:24 PM
bad venge's Avatar
bad venge
Section Moderator
I take it the mtx has two wires it should be 12 volts on one side and the light on the other side
I'd rewire it like that leaving the third wire on the atx harness disconnected
Old Jan 27, 2008 | 12:51 AM
97wbody's Avatar
97wbody
one of them is for the clutch switch no?
