mega squirt
Old Feb 4, 2008 | 09:44 AM
96 srt4's Avatar
96 srt4
Default mega squirt
has any one here expiramented with the mega squirt system. i was wondering if that was the way to go if your wanting to turbo later?
Old Feb 4, 2008 | 01:31 PM
95to96transplantneon's Avatar
Default RE: mega squirt
Even with a stock motor you can get quite a bit more power from MS, you have to remember your pcm is tuned for economy in mind hence seriously de-tuning you motor... With MS you can get around all those little things and let your motor perform to the max. no matter what your setup...
Old Feb 5, 2008 | 01:32 PM
96 srt4's Avatar
96 srt4
i have been told about ms but where do you get it on the internet?
Old Feb 5, 2008 | 01:51 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Talk to spikeymikey on the sec gen forum, he did what u are thinking of doing, he started with the ms, then turboed it later.... he would be ur best bet for info on the ms, i am going to run it this year but have not started the setup
Old Feb 5, 2008 | 02:14 PM
12 volt's Avatar
12 volt
ORIGINAL: 96 srt4
http://www.diyautotune.com/
transplant knows another good site
Old Feb 5, 2008 | 03:10 PM
http://www.rs-autosport.com
these guys sell the MS with maps for our motors so it allready has a base map for a 420a i know our motors are not 420a's but they basicly are exept the head has been switched around... so all you have to do is install it, load the pre-made map, and it runs like you stock neon... then you can tune the map from there... just back up the origanal file so if you mess up to bad you can just reload the good one...
Old Feb 6, 2008 | 12:52 PM
96 srt4's Avatar
96 srt4
they are tuneable with a laptop right.
Old Feb 6, 2008 | 01:48 PM
12 volt's Avatar
12 volt
yes
http://www.megamanual.com/v22manual/mintro.htm
Old Feb 6, 2008 | 08:08 PM
rayraydoet's Avatar
rayraydoet
squirt from rs auto is a mega squirt 1 not a 2. so shouldnt we use a mega 2 instead? and if i build it my self wat mod kits do i need? and how do i add sihft light control and launch control? and should i use the new experimental ignition mod from rs so i can use higher dwell? i was thinking of geting the msd coil pack maybe that can handle a higher dwell
Old Feb 6, 2008 | 09:29 PM
rayraydoet's Avatar
rayraydoet
and can the mega squirt control the automatic? and how do you raise when and auto shifts at? is it controled by the computer? do i have to get a af/x computer to make the auto shifter higher? along with mega squirt?
