start up problem?
start up problem?
Hey guys need some help.3 days ago my 1995 neon dohc started idling really bad when first started.Dies alot too.It will idle around 400-500 rpm until about 10 minutes unless it dies.When I give it gas the rpms dont even move it just seems like it makes it worse.Gradually the rpms will go up after 10 minutes or so and it will run fine.one of my buddies looked at it and send possibly the engine coolant temp sensor?It is also winter where I live if that helps at all.Thanks.
RE: start up problem?
it coiuld be a whole bunch of things ...run a scan tool on it to get any codes it may be throwing...start there..all those sensors could be bad ...i jsut had a problem simular with my daily driver ..granted its a sunfire but its the same concept...my problem was the evap system
