cylinder 3 misfire error code
Old Feb 13, 2008 | 11:14 PM
vlmuke's Avatar
vlmuke
Default cylinder 3 misfire error code
I just pulled the error code from my neon today one of the error code was a cylinder 3 misfire the plud and wires are new is this mean my coil is on the fritz as there is no distibutor? any thoughts on it would be appreciated
Old Feb 14, 2008 | 12:28 AM
dirt_trac_racer_80jr's Avatar
Default RE: cylinder 3 misfire error code
did you go over ur injectors
Old Feb 14, 2008 | 04:28 AM
vlmuke's Avatar
vlmuke
no I haven't, I run injector cleaner with every tank though I've only had the car a few months
Old Feb 19, 2008 | 04:11 AM
could be plugs could be wires ..could also be the coil itself ...just because u run injector cleaner doesnt mean that there isnt a piece of dirt plugin the injector
Old Feb 19, 2008 | 12:59 PM
das2123's Avatar
das2123
Can you feel the miss? Unplug your injectors while the engine is running one by one and see if the engine stumbles.
Old Feb 20, 2008 | 03:50 PM
vlmuke's Avatar
vlmuke
no it runs great I cleared the codes and no misfire code just the downstream o2 sensor how ever after it threw the code the whole dash panel would blink anf the whole car would shudder for a second but after I reset it, it stopped so I don't know what is going on the plug wires and plugs only have less than 1000 miles on them
Old Mar 21, 2008 | 07:17 PM
lwayfan's Avatar
lwayfan
I have near the same problem. My neon runs fine cold, but gets very bad warm. I have a newer fuel pump. New fuel filter, plugs, wires. I tried a different coil, and PCM. I sometimes have a tough time reaching 20 mph! Please help.
Old Mar 22, 2008 | 01:05 PM
12 volt's Avatar
12 volt
ORIGINAL: lwayfan
dont be afraid to start a new post if you have a question. no post highjacking
