A Friend Needs Help.
Old Feb 15, 2008 | 06:35 PM
reaperof_evil's Avatar
reaperof_evil
Default A Friend Needs Help.
my friend has a 96 neon 5spd with a 2.0 block and 2.4 head it was running fine till last week its sputters at around 3k we changed the coil computer plugs plug wires and cant seem to find out why it sputters can anyone help as soon as possible he needs his car for work. thanks
Old Feb 15, 2008 | 07:00 PM
95to96transplantneon's Avatar
Default RE: A Friend Needs Help.
lots can cause that check plugs wires all that good stuff do a compression test leak down blah blah blah...
btw 2.4 head and 2.0 head are EXACTLY THE SAME...
Old Feb 15, 2008 | 07:07 PM
reaperof_evil
I ment a 2.0 sohc block with 2.4 dohc head sorry. lol yeah we put new plug wires on and a new computer and coil pack and plugs it fires right up. But when you drive it for alittle it sputters at 3k or higher we checked the timing it was fine im geuss its miss firing some how i just cant seem to figure it out.
Old Feb 15, 2008 | 08:32 PM
you check the injectors to see if there firing???
just turn the car on and get a long flat blade screwdriver put the tip to the injector and the handle of the screwdriver to your ear... you should hear a steady tick if it is not steady or no sound... you have a bad injector...
Old Feb 15, 2008 | 09:58 PM
12 volt's Avatar
12 volt
o2 sensor will do that too
Old Feb 16, 2008 | 12:35 AM
reaperof_evil
thanks guys i hope we can figure it out soon
Old Feb 17, 2008 | 03:39 AM
pimpberetta's Avatar
pimpberetta
Check your iat/map sensor. It will cause a rev limit or a sputter.
Old Feb 17, 2008 | 02:09 PM
reaperof_evil
we changed the fuel pressure regulator and it doesnt do it as bad now but the o2 censor was showing up on the computer when we ran it the could the o2 censor be causing it to sputter
Old Feb 17, 2008 | 02:46 PM
12 volt's Avatar
12 volt
The result is poor driveability, manifested by one or more of the following symptoms:
ยท decreased fuel economy
ยท hesitation on acceleration
ยท stalling
ยท surging
ยท rough idle and
ยท increased tailpipe emissions (with a likely failure of emissions tests, where mandated).
In addition to driveability problems, a faulty O2 sensor can lead to premature failure on the catalytic converter.
http://www.bennettauto.com/oxygen_sensors.html
Old Feb 17, 2008 | 03:05 PM
reaperof_evil
so if the cats hollowed out it will run like **** and sputter at 3k rpm? or is it just the o2 sensor we chnaged everything else
