Compression Problems
Old Feb 17, 2008 | 03:28 PM
sabin420's Avatar
sabin420
Default Compression Problems
Got a 95 neon w/ a remanufactured motor...went to start it up and can't get any compression...sometimes I might get as much as 150psi...but most the time it's beween 30 and 60 psi...any easy solutions, or am i gonna have to take the head in to have the valve seats reground.
Old Feb 17, 2008 | 03:46 PM
12 volt's Avatar
12 volt
Default RE: Compression Problems
welcome to the forum!
assuming you did a direct compression test. Makeing sure the engine is warmed up is important to getting a good test. within 15% of 190 is good.
Doing a differential compression test can help you find where the leak is without removing the head.
Old Feb 19, 2008 | 09:19 PM
sabin420's Avatar
sabin420
Can't warm up the car to do a compression check...the engine has never been started up b4. I'm trying to get it to fire off for the first time...When I do get compression, it holds the compression and doesn't bleed off the pressure.
Old Feb 20, 2008 | 12:26 AM
12 volt's Avatar
12 volt
well maybe the gaps in the compression rings lines up for a minute and that gave you the loss. Personally i perfer to do differential compression checksbeacuse its some much easyer to fin the leaks.
is it just one cylinder or more?
Old Feb 20, 2008 | 12:43 AM
master tech's Avatar
master tech
Site Moderator & Tech
I agree with 12 volt, I would also put little ATF in each cylinder and start. This may help the compression ring to seat.
Old Feb 29, 2008 | 01:31 PM
sabin420's Avatar
sabin420
I ain't used ATF...I've tried a lil bit of motor oil...that does help a lot...but still no start...I am shootin 3-4 foot flames out the exhaust every now and then too.
[IMG]local://upfiles/84129/6F79D3D0D0D3455BBBDB18A8F0BEFDD1.jpg[/IMG]
Old Feb 29, 2008 | 01:38 PM
Spawne32's Avatar
Spawne32
sounds like a bad engine imo
Old Feb 29, 2008 | 03:32 PM
12 volt's Avatar
12 volt
ORIGINAL: sabin420
afterfire occures when you have unburnt fuel in your exhust system or an exhaust leak. i would testing fuel pressure, then spark
Old Mar 1, 2008 | 11:11 AM
sabin420's Avatar
sabin420
Spark is good....REAL GOOD...MSD Coil, Solid Core Stanless Steel Plug Wires and Gapped at .040" and I got an Adj. Fuel pressure Regulator...50psi...I been sick so I ain't been out there to try anything else yet..
Old Mar 1, 2008 | 01:47 PM
95to96transplantneon's Avatar
when did you install the fpr... and how did you set it up???
