what trans
Old Feb 22, 2008 | 06:03 PM
droppedneon's Avatar
droppedneon
Default what trans
i have a 97 neon. im going to be putinga dohc in. i have a 5 speed sohc trans could i use that on the dohc motor or not ? if it will work will the trans just suck for that motor?
Old Feb 22, 2008 | 06:18 PM
Slashwannabe's Avatar
Slashwannabe
Default RE: what trans
The SOHC and DOHC block are the same exact thing.
Yes it will work.
Old Feb 22, 2008 | 06:29 PM
droppedneon
ok now i know it will work. does anyone know how itwill runwith the dohc motor and the sohc trans? i know i should get the dohc trans but i really dont see many dohc neons in the junk yard around here. if i do most of the time there is no motor or trans or thay want to hit u over the head with the price for it.
Old Feb 22, 2008 | 07:30 PM
Slashwannabe
they both use the same tranny automatic and manual.
Old Feb 22, 2008 | 07:53 PM
95to96transplantneon's Avatar
The block and trans are exactly the same on both the sohc and the dohc... they will bolt up and work the EXACT SAME...
Old Feb 22, 2008 | 08:37 PM
12 volt's Avatar
12 volt
Yes it will work.
x3
Old Feb 23, 2008 | 09:07 AM
droppedneon
wow ok that cool i didnt know about the trans being the same.
Old Feb 24, 2008 | 08:14 AM
Ghost Neon 2's Avatar
Ghost Neon 2
The sohc trans will give you the best mileage, but the dohc mtx will provide better acceleration. The 1G sohc mtx has a 3.55 FD with a .72 fifth gear. Very trall gears for good mileage. The dohc mtx has a 3.94 FD with a .72 fifth gear. The higher final drive makes for an increase in acceleration given the shorter gears. The r/t mtx has the 3.94FD with a .81 fifth gear. This provides an 11% increase in acceleration with the very short gears. Ideal for any n/a neon. It is what I am using currently.
Old Feb 24, 2008 | 05:14 PM
bone33's Avatar
bone33
ORIGINAL: Ghost Neon 2
great info. just so the OP knows, all these different trannys fit both engines.
