head clearance
Old Mar 5, 2008 | 05:52 PM
neonracer1010's Avatar
neonracer1010
Default head clearance
would it be safe to take 4 thou off? head is warped about 2-3 thous the extra thou would be just to clean it up
would it be ok
Old Mar 5, 2008 | 10:35 PM
neonracer1010
Default RE: head clearance
well turns out its gonna be about 20 thous gettin taken off.
am i gonna have a problem with timing
Old Mar 6, 2008 | 12:21 PM
HarleyRider68's Avatar
HarleyRider68
I took 28 off mine, but re-cammed with a Crane.
Old Mar 6, 2008 | 01:48 PM
scramer05's Avatar
scramer05
i have 30/1000ths taken off of mine with crane 16s and its fine
Old Mar 6, 2008 | 02:37 PM
neonracer1010
i will still be using stock cams though so will i have any interfence problems? will i need new cam gears
Old Mar 6, 2008 | 03:00 PM
95to96transplantneon's Avatar
you wont have an interferance problem if you time your car correctly when you re-install your timing belt... you will not need new cam gears.... It never hurts to go out and get a degree wheel and do it the right way...
