Bought the 2.4 today
Old Mar 12, 2008 | 03:11 PM
  #41
neonracer1010's Avatar
neonracer1010
Default RE: Bought the 2.4 today
SLASH SHUT UP[8D][8D][8D]
haha j/k
Old Mar 12, 2008 | 04:48 PM
  #42
boxerjl2's Avatar
boxerjl2
is the map clamp pointless for a Na Engine?
Old Mar 12, 2008 | 09:23 PM
  #43
boxerjl2's Avatar
boxerjl2
im not really sure what the map clamp is and i was just curious if it is pointless to put on a Na engine
Old Mar 12, 2008 | 10:05 PM
  #44
95to96transplantneon's Avatar
first off slash a wide band o2 sensor never lies...
the map clamp is neccicary due to the map not being able see boost and the pcm freaking out from the boost... it will cause the map to read high all the time causing the car to dump fuel... then you take your foot off and it over compansates when it goes to lean out the car so it dumps tons of fuel then it leans out... kind of a vicious cycle... the map clamp just lest the map see vac and bypasses the boost... mechanical type... or it clamps the voltage at 0-5 volts via a dial... you just dial in where your car is happy and dont freak out... electronic type..
Old Mar 13, 2008 | 02:02 AM
  #45
12 volt's Avatar
12 volt
no such thing as pre detonation
Old Mar 13, 2008 | 02:44 AM
  #46
no offence to boxer but I sware I have lost over 30 mins of my life on this post... It makes me sad...
Old Mar 13, 2008 | 02:54 AM
  #47
boxerjl2's Avatar
boxerjl2
ok so next year i will have to worry about that when i get a turbo well after all the other stuff
Old Mar 13, 2008 | 12:26 PM
  #48
boxerjl2's Avatar
boxerjl2
hey atleast im learning something
so i faxed the shipping papers to the place today so i should be recieveing the engine within 10 days
Old Mar 14, 2008 | 06:44 AM
  #49
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: 95to96transplantneon
First off I'm running a Map clamp and you aren't 'Nuff said. Your aextremly nice and politedude and90% of the time you have usefull trueinformationbut sometimes you just run off at the mouth withstuff that is based off of somebody elseshearsay.
You wouldn't have an IAT sensor if the other sensors didn't somewhat rely on it to give an acurate reading.
Which brings me to the main fk up I did, I used a 3.9k ohm resistor and I'm running too rich,I read on Auto Zones online repair gudethat normal operating temp is listed between700-1,000 ohms at the IAT on the Neon.Iput a 2,000 Ohm resistor so I'm just slightly more rich than stock, nowI got fast starts again and decent fuel consumption and better low-mid and high range. The great news is that I haven't pinged once.
Old Mar 14, 2008 | 02:47 PM
  #50
ORIGINAL: Slashwannabe
how is my statement of a wideband 02 sensor never lies, wrong... you still have no idea really where you are with your a/f ratio in any way shape or form you could be running lean as hell witch i pretty much know you are up top since you have no way of getting the extra fuel to your carwhen thereboost present... you should know that more air means more fuel, just by adding a resister youare just tricking the iat so the pcm dont freak out, your not adding fuel in any way.you cant just say by sticking this resister in here its going to give me x for a a/f ratio...
And It really dont matter if your running a map clamp and I'm not... Facts are facts and shady mechanics are shady mechanics... Wide bands are a MUST, if you want to do it RIGHT.... your way works but for how long???
