Information for a 2.0 engine swap - SOHC to DOHC
Old Nov 20, 2013 | 05:41 PM
  #41
vickie223's Avatar
vickie223
Default Dohc for sohc engine idles rough getting miss firing codes
hey every one I jst did a 2.0 dohc engine swap for a sohc engine....will we need to swap THE BRAIN ECU ALSO?
Old Mar 21, 2014 | 03:54 PM
  #42
cmonty92's Avatar
cmonty92
i have a question what would happen if you put dohc pistons in a sohc motor?
Old Aug 25, 2014 | 09:18 AM
  #43
atwell17's Avatar
atwell17
Default dohc to sohc
If I swap from a dohc to a sohc being just the head swap and keeping the block do I have to change the wiring harness or can I change out the sensors in the head and the computer n call it a day?
Old Jan 2, 2017 | 09:15 PM
  #44
Mercedes Kosha's Avatar
Mercedes Kosha
I have an Sohc '97 Neon that I have set up to race dirt track. I have all the performance parts I can possibly get my hands on, except for the dohc engine. Would anyone recommend this for a racing engine? I've heard of tons of people using them, but need more input.
Old Jan 9, 2017 | 10:19 PM
  #45
sabin420's Avatar
sabin420
The main advantage to the DOHC motor is the ability to individually adjust the intake and exhaust cam advancement with an adjustable cam gear. Also, turbo parts are widely available for the DOHC but not the SOHC. If you are going naturally aspirated, I would keep the SOHC. If you want to turbocharge the car, go with the DOHC.
I've personally gotten a good 270 hp out of a SOHC bored .060 over, stroked, JE pistons, Eagle connecting Rods, ported, shaved head, Crane Cams #16 cam, high compression, Indy intake manifold, 60mm throttle body, MSD ignition, Custom fuel map and spark advance, Underdrive pulley, Lightweight flywheel, Mid length headers to a straight pipe. Keep in mind that this was about 15 years ago. Some of these parts are no longer being made and will be difficult to locate. I also have personal access to a fully equipped automotive machine shop with all sorts of CNC machines.
Old Mar 25, 2017 | 09:17 AM
  #46
racerx80p's Avatar
racerx80p
Default dohc sohc swap
ok I have a dohc putting the head off a sohc what bolts should I use also what head gasket should I use
Old May 16, 2019 | 09:11 PM
  #47
Randi Smith's Avatar
Randi Smith
Default 2000 dodge neon engine block swap
Hi I would love to get some insight. I bought a 5 speed 2000 dodge neon with a rod thrown through the block. So I found a 2003 automatic dodge neon engine and decided to swap the blocks. (I had to modify the wiring harness) after completing the job it won't start. Can anyone give me some insight on what I did wrong or why it didn't work I'm lost. And honestly don't know a lot about neons. But I really thought it would work. And I would still really like to get it running if possible
Old Mar 15, 2023 | 02:16 AM
  #48
Donking206's Avatar
Donking206
Question sohc to dohc swap
I've straddled across this thread through a few searches on google, I was wondering if the swap can work with the 96-99 DOHC head to a 2000+ 2.0l SOHC block? may be a stupid question but just curious.
