CHECK ENGINE LIGHT!!!!!
Old Mar 27, 2008 | 07:36 PM
firstgenneon's Avatar
firstgenneon
Default CHECK ENGINE LIGHT!!!!!
i got a check engine light by removing the positive on the battery for about a min will it take it off? or is their a better way or another way to do it?
Old Mar 27, 2008 | 07:47 PM
chenzo's Avatar
chenzo
Default RE: CHECK ENGINE LIGHT!!!!!
to find out why your check engine light is on..
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the
engine on.
when you get a code 55, that means thats the end of the codes. come back with the code number and im sure someone can help you.
Old Mar 27, 2008 | 10:29 PM
droppedneon's Avatar
droppedneon
i have a check engine light on to. its number 35 anyone know what thats for?
Old Mar 27, 2008 | 11:02 PM
95to96transplantneon's Avatar
35 Rad Fan control relay circuit
Old Mar 27, 2008 | 11:04 PM
What year car do you have??? And I can give you an answer what you need to do...
Old Mar 27, 2008 | 11:49 PM
firstgenneon
i got 3 engines codes from the cpu i got 12, 22, 43 lol wow my neons ****ed up
Old Mar 28, 2008 | 12:15 AM
for further discussion please see this post...
https://dodgeforum.com/m_1245146/tm.htm
he double posted so just to keep all info in one post please see other post above...
