MY RT, IF IT WORKS OUT..PICTURES UP.. Spud&Jeremy what you think
#51
#52
im really hopeing i get it so that i can have a sweet neon and not have an everyday neon.. whichi guess the neon is still the every day neon but its not often that you see nice neons around here were every part is a differant color or every part is falling off
#53
I own a 99 R/T in that style you posted and I love it to death. My mom bought it in 99 with 13k miles, and 140k miles later, I bought it from her, and I still love it. It runs like a champ. Never had a check engine light once. I'll cry the day I have to sell it and finally get a brand new car. But if you do manage to get it, I think you'll be a very happy owner. It's little, it's fast (as fast as a 5spd neon can be
) , looks awesome, and gets GREAT gas mileage. 175k miles later i'm finally getting a new clutch, if that isn't great craftsmanship, I don't know what is haha.
![Stick Out Tongue](https://dodgeforum.com/forum/images/smilies/tongue.gif)
#54
#56
i think its going to be freeken SICK that torque is undeniable 165 lbs compaired the the 2.0 130 i mean i really dont know what to expect but i know its going to be way better and hopefully its going to be worth it i have about or even over $1000 into the engine already,, not including the price of the engien,, and i got all my parts from other users of the DF and ._Org
here is what all ive boughten
2.4L Stratus motor $995
2.5' exhaust $220
F1 Stage 1 Clutch $203
Timing Belt Kit $186
DOHC Mopar PCM $145
2.4L Mount Adapter $70
Dohc wiring harness $70
PT Water Inlet $25
Complete Gasket Kit $60
DOHC Header $60
Underdrive Pulley $60
24 # Fuel Injectors. $50
2.0 Cams And Gears $48
Granatelli Wires $48
Water Pump $46
Lower ALT Bracket $43
Complete Solid MM Bushings $40
Intake manifold $38
Fuel Rail $30
Thermostat housing $26
Booger Bushings $22
EGR block off kit $20
2.4 Alternator Belt $19
Knock Sensor $17
2.4 Motor Mount $15
ALT Upper Bracket $12
Valve Cover Filter $11
DOHC Thermostat $10
Upper Rad hose $10
Lower Rad hose $9
Vaccume Lines $0
DOHC heater hard lines $0
and most of that is to make it work but there are some peformance parts there
but i think it will be well worth it even if i dont get that RT
2.5' exhaust $220
DOHC Mopar PCM $145
PT Water Inlet $25
DOHC Header $60
Water Pump $46
Intake manifold $38
Fuel Rail $30
Booger Bushings $22
Knock Sensor $17
2.4 Motor Mount $15
DOHC Thermostat $10
Upper Rad hose $10
Lower Rad hose $9
Vaccume Lines $0
#57
#58
#59
sumthing i was just thinking about....
too bad you might not get the r/t and you arent going to neons2k8.....ive got a nice blue passenger door from my old 2-door r/t sitting in my moms basement...atleast i think it should still be there....
EDIT
oh yeah and why did you take it off your Rt
