Dodge Neon Speedometer Panel
Old Mar 29, 2008 | 02:04 PM
neon91's Avatar
neon91
Default Dodge Neon Speedometer Panel
I have problems with my speedometer panel. It does't show the speed that I am driving with, it just stays at 0. Any suggestions on why it is doing this ?? Thank you!
Old Mar 29, 2008 | 02:17 PM
JackMehoffer69's Avatar
JackMehoffer69
Default RE: Dodge Neon Speedometer Panel
ORIGINAL: neon91
Go contact Slashwannabe he had the same problem last week and fixed his.Jeremy gotslashbanned now though so might be hard to get ahold of him.
Old Mar 29, 2008 | 02:22 PM
neon91's Avatar
neon91
Do you know where the threat was in the forum ? If not, its all good. Thanks a lot for replying!
Old Mar 29, 2008 | 02:38 PM
JackMehoffer69
ORIGINAL: neon91
he was banned before he could post his findings.
Old Mar 29, 2008 | 02:43 PM
neon91's Avatar
neon91
Alright thanks.
Old Mar 29, 2008 | 02:46 PM
JackMehoffer69
ORIGINAL: neon91
Alright thanks.
You might want to think back if you went through any puddles or water sources cuz a friend of mine had that happen to his car driedthe speed sensorout and it worked again. Or you can take your cluster out and see if any of the soldered joints are broken or bruised.
Old Mar 29, 2008 | 02:53 PM
neon91's Avatar
neon91
i was thinking about the cluster. It can't be water because this is been a problem for a while.
Old Mar 29, 2008 | 02:54 PM
p8ntballa113's Avatar
p8ntballa113
From what i hear it is a problem with the connections of a couple wires. You can either buy a new used speedo for like $60 on ebay or fix it yourself. 9596 transplant knows i think. Try poping it out and looking at it, it's easy to take out.
Old Mar 29, 2008 | 02:56 PM
neon91's Avatar
neon91
Okay! I will try taking it out and check the wires. I really appreciate your help guys.
Old Mar 29, 2008 | 03:20 PM
95to96transplantneon's Avatar
this is the classic re solder problem... he just needs to reflow his cluster...
