Dohc swap info
Old Mar 30, 2008 | 12:00 AM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Dohc swap info
Well I picked up the dohc that ol skool was selling. My first dohc neon engine ever. I get there and he is like "I got another if you want it free for buying this one. It has a bad bottom end". I said hell yea. First off. How much boost can I run safely on a sohc bottom and dohc top? Where can I find a safe thicker head gasket to lower the compression more? I notice the the oil pan is different. Should i use the oil pan off the dohc? It has fins on it. Is it worth using a sohc to dohc turbo mani conversion thing or should i just go get a dohc mani? One more thing. This may sound like I am stupid. WHat makes a dohc red line higher then a sohc? Is it just the rev limiter or can a dohc engine go higher because of the dual cams?
Old Mar 30, 2008 | 12:16 AM
95to96transplantneon's Avatar
Default RE: Dohc swap info
Your just going to be safer from detonation by running that head block combo... you may be able to turn it up a hair but i would honestly leave it 7-8 so you have the extra insurance from a lower compression ratio... dont lower it more... use the dohc oil pan... imho its designed better for oil pick up... the red line is higher due to the higher compression and the ablity of the dohc head to breath better...
get a dohc turbo manifold or just get the srt-turbofold... it bolts straight up, plus you can shut it off... if you want due to the manifolds design...
Old Mar 30, 2008 | 12:20 AM
I_Ride_Neon
So sohc on a dohc the redline will be 7.2? What if I used sohc on the dohc for high compression. are you saying my redline would be higher because the compression would be higher. I have been running 10 psi all day in the neon. Will my garret bolt up? Or do i need to use the srt4 turbo also?
Old Mar 30, 2008 | 12:33 AM
no the srt turbofold is one part... only the srt turbo will fit on its a single unit and odd if you really look at it...
and the pcm controlls the rev limiter... so if you put a dohc on there you will get the 7200rpm limiter... if you use a sohc you will get the 6500
Old Mar 30, 2008 | 12:40 AM
I_Ride_Neon
So I can safely red line it with the 7.2 limiter without blowing it up? With the dohc head.
Old Mar 30, 2008 | 12:46 AM
yeah... with the dohc head... you will be making power up there...
Old Mar 30, 2008 | 01:05 AM
ryleynoyes's Avatar
ryleynoyes
yes, you can go to 7200 (7250 actually i believe)
but don't hang up there and bounce it off the rev limiter, or rev up there too much if you haven't upgraded the valve springs to prevent valve float
valve float (if bad enough) WILL destroy the engine, as the dodge 2.0 is an "interference" engine, meaning the pistons will make contact with the valves if the timing belt breaks (or other reason that the valves are open when they shouldn't be)
Old Mar 30, 2008 | 01:10 AM
I_Ride_Neon
Cool thanks. I always wanted to know what life over the 7k mark is like.
