WHAT'S THE BEST C.A.I. ROUTE???????
Old Mar 31, 2008 | 12:35 PM
mcss8541's Avatar
mcss8541
Default WHAT'S THE BEST C.A.I. ROUTE???????
Hey all I bought one of those C.A.I. kits that you can pice together and design your own. What is the best route to run it? I have a 1997 Neon 2.0 SOHC with a MTX. I am buying one of the members' 52mm TB but for the life of me I can't see where to put it. Part of it is a flexible hose that extends 28" and has "memory" position. Thanks!
Old Mar 31, 2008 | 12:46 PM
12 volt's Avatar
12 volt
Default RE: WHAT'S THE BEST C.A.I. ROUTE???????
yours will be different, but somthing kinda like this will give you the best air
https://dodgeforum.com/m_833897/tm.htm
Old Mar 31, 2008 | 12:47 PM
boxerjl2's Avatar
boxerjl2
https://dodgeforum.com/m_1240508/tm.htm
theres a good recent post about the temperatures
Old Mar 31, 2008 | 04:09 PM
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
If you dont have smog laws, the link that 12 volt put up is the best way to go, more then likely you'll be fine this way, i think cali is the only place strict enough to not allow that, also check out the second link that boxer put up, its a little test on engine bay temperatures in differant typical cai areas
Old Mar 31, 2008 | 04:42 PM
mcss8541's Avatar
mcss8541
I appreciate the help. 1 question, with the filter being that low to the gound would'nt water get sucked up into the intake?
Old Mar 31, 2008 | 04:43 PM
mcss8541's Avatar
mcss8541
mcss8541's Avatar
mcss8541
Old Mar 31, 2008 | 04:49 PM
iwalton63's Avatar
iwalton63
ORIGINAL: mcss8541
yes sir.
be ready to dodge those puddles.
Old Mar 31, 2008 | 04:56 PM
spudsterier's Avatar
spudsterier
i have a home made cold air intake that sits that low and i drive through big puddles all the time....havent had any problems yet
Old Mar 31, 2008 | 06:55 PM
95to96transplantneon's Avatar
mine sits really low and dont have a problem with it... at all...
