trouble starting
Old Apr 4, 2008 | 10:17 PM
  #21
95to96transplantneon's Avatar
Default RE: trouble starting
far shot here but are your tires straight ahead??? i know it sounds weird... I will be getting at something from your answer...
Old Apr 4, 2008 | 10:21 PM
  #22
mcallan911's Avatar
mcallan911
Hmm I am at work now, but I'm 90% sure that they are.
Old Apr 4, 2008 | 10:25 PM
  #23
what im trying to get at is if the steering wheel is locked out and there is tention on the wheel just pull the wheel a tad bit away from the tention then try to start it... go out and look at the wheel if its not straight this may be your problem...
Old Apr 5, 2008 | 03:15 PM
  #24
vegas_neon's Avatar
vegas_neon
have u try starting it in any other gears?
Old Apr 5, 2008 | 03:18 PM
  #25
12 volt's Avatar
12 volt
It clicked everytime I pushed the coper pigtail wire in
it should click everytime you turn your key too. Get someone else to ensure that the relay is closeing when you trun your key.
Usually when it just clicks it means the battery is low or the starter isnt getting enough power. Ive never messed with a neon starter so i wouldnt know where the ground is, most starters are internaly grounded.
Hope i helped some, its hard to troubleshoot when the car isnt in front of you.
Old Apr 5, 2008 | 05:06 PM
  #26
mcallan911's Avatar
mcallan911
Hey NP you have helped lots.
It f**king snowed last night and is cold today so I can't check anything. The next thing I will check is the wire plug that goes into the starter, maybe that is not getting a signel.
Old Apr 7, 2008 | 08:57 PM
  #27
mcallan911's Avatar
mcallan911
So I finally had time to test the car again.
I got someone to turn the key while I watched the relay and the relay never engaged.
So that means what? lol
Old Apr 7, 2008 | 09:25 PM
  #28
mulletman11's Avatar
mulletman11
wow super unlucky all this **** you changed and still nothing
have u tried bump starting it?
Old Apr 7, 2008 | 11:57 PM
  #29
mcallan911's Avatar
mcallan911
Yea I tried that.
But whats still strange is why the starter wont turn when I put jumper cables on it and a battery from a running car.
It's something between me putting in my key and turning, and the relay.
Could it be the ecu? Whats the link between those 2 things? Anyone have a Helms for this car?
Old Apr 8, 2008 | 12:08 AM
  #30
if I remember right you can just sqeeze the relay and make it engage... LIKE I SAID I THINK I REMEMBER... IM NOT RESPONSIBLE FOR YOU DIEING... LOL... I SWARE I READ IT SOMEWHERE THOUGH...
