Relocate Battery to trunk
Old Jan 2, 2005 | 07:33 PM
98neonsport's Avatar
98neonsport
Default Relocate Battery to trunk
I was wondering if anyone could send me the link on how to do this. I know it has came up on this post a lot but i couldnt find it so i just need a link. Thanks
Old Jan 2, 2005 | 07:50 PM
casper's Avatar
casper
Default RE: Relocate Battery to trunk
The easiest way to do it is to get a Gel, or dry battery and a battery box for the trunk and run 0 or 00 gauge wires under the car. Make sure that you route the wires carefully and make good connections.
Old Jan 3, 2005 | 07:06 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Or you can do what I did.
Its not easy and requires the use of a good drill and some elbow grease but its better than running wires under thre carpet or under the car.
I can get you a how-to, just give me some time to get it together. You can't do mine in a few hours like most of these other relocations, its going to take you at least 6 hours to do it.
Old Jan 3, 2005 | 10:36 PM
RT_Driver's Avatar
RT_Driver
This is the link you might be looking for:
http://neons.org/howtos/relocateb.shtml
Old Jan 3, 2005 | 11:00 PM
Cr@zy Squ33
No. Thats not how I ran mine.
Old Jan 11, 2005 | 01:35 AM
98neonsport
How did you run yours squee?
Old Jan 11, 2005 | 01:38 AM
casper's Avatar
casper
I believe he ran it through the frame rails, if I rember right from an earlier post. It is not needed to do it that way, but it is the most perfesional and best looking in my opinion. It also take a while to do it the right way.
Old Jan 11, 2005 | 01:50 AM
Cr@zy Squ33
Yes, I ran it through the rocker panels. Took about 6 hours to run the ground wire and positive cable through it.
