Water deposit boiling, HELP!
Old Apr 7, 2008 | 01:14 AM
RedNBlack99's Avatar
RedNBlack99
Default Water deposit boiling, HELP!
I, have a problem, after i go for a ride, and I park, there is a strange sound coming from the glovebox. I opened the hood and found that the water deposit was boiling, even though it had anti-coolant. What can by the problem?? How can i fix this???
Old Apr 7, 2008 | 01:15 AM
mulletman11's Avatar
mulletman11
Default RE: Water deposit boiling, HELP!
not the right mixture
or you used tap water
or ur running at liek 300degrees which is not good at all
either or
Old Apr 7, 2008 | 01:20 AM
95to96transplantneon's Avatar
It sounds like a thermostat that wont open and your overheating... or like mullet said your running to weak of a mixure...
Old Apr 7, 2008 | 01:38 AM
mulletman11
go either buy 50/50 mix at a store
or use distilled water and anti freeze half and half parts
water biols at 212 common knowledge
by adding somehting else into the mix, anitfreeze, u make the water impure, casuing the boiling point to go way up, cause i car can run hotter than 212
same reason why salt water freezes at 27 instead of 32, impure
ur mix, i think, is too watery and is evaping an boiling off so u have no more coolant
Old Apr 7, 2008 | 07:51 AM
neonracer1010's Avatar
neonracer1010
so if im running straight water,it will evaporate eventually?
Old Apr 7, 2008 | 08:19 AM
mulletman11
yea it will not cool as efficently
and will boil off eventually
and if its not distilled water, if its tap water, it can leave deposits in ur collant system and clog things upp pretty bad
Old Apr 7, 2008 | 11:58 AM
12 volt's Avatar
12 volt
ORIGINAL: neonracer1010
Q. What is the best antifreeze/coolant concentration for a vehicle? Can I use 100% antifreeze?
A. We recommend that you use between a 50% and 70% concentration of antifreeze. At least 50% is necessary to give the adequate amount of corrosion protection, as well as freeze/boilover protection. However, we do not recommend more than 70% antifreeze. This would cause restriction of the heat transfer capabilities, corrosion protection, and freeze protection. The concentration of freeze/boilover protection of the antifreeze mixture can be checked using a Prestone® Antifreeze Coolant Tester.
http://www.prestone.com/carcare/faq.php
Old Apr 7, 2008 | 10:35 PM
neonracer1010
that doesnt help me much
i have striat water rite now will it evaporate over a week perioid
Old Apr 7, 2008 | 11:38 PM
mulletman11
no, not that quick
but check it and go to thee store and buy some antifreeze and add it
Old Apr 8, 2008 | 01:24 AM
12 volt's Avatar
12 volt
you probably have a blown head gaskit.
is this the first time its over heated?
