okay getting P/O radio wiring
Old Apr 11, 2008 | 11:41 AM
craigsharp's Avatar
craigsharp
Default RE: okay getting P/O radio wiring
Factory Speakers? Do all the speakers go out or just one? If all 4 then it's going to be in your harness with loose wires.
Old Apr 11, 2008 | 01:07 PM
12 volt's Avatar
12 volt
or the head unit
Old Apr 11, 2008 | 05:06 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
ORIGINAL: craigsharp
all the speakers go out at once. and its not the head unit because the old stock radio did the same thing. but, its been awhile since the stock headunit was in there i will look for it and maybe reinstall it to rule out the headunit
Old Apr 11, 2008 | 05:10 PM
craigsharp's Avatar
craigsharp
where'd you buy your harness from? if it's one from best buy you had to connect the head unit's bare wire to the harness somehow, how did you do it? twist and tape? twist on connectors? or twist + solder then tape? I did the latter and no problems have arrived. I would suggest instead of black electrical tape, that you use some shrink tape. that works very well.
Old Apr 11, 2008 | 08:21 PM
DOHCgarrett t3
twist solder tape then Ziptied the wires individualy together honestly im pretty sure its not the harness. the car was all ghetto rigged when i got it i been working out the bugs since then. its mainly wiring issues. i just dont understand why all the speakers would all go out at the same time. guess ill check the ground later.
Old Apr 11, 2008 | 08:47 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I bet its a speaker wire shorting out and kicking on the protector in the cd player to turn the channels off.
Old Apr 11, 2008 | 10:37 PM
DOHCgarrett t3
OKAY, ALL FIXED NOW. WHAT WAS HAPPENING WAS THE STOCK PORTION OF THE HARNES. THE BLACK CLIP WAS AND STILL IS ****TY AND SOMEHOW DIDNT MAKE A CONNECTION. I STILL DONT KNOW HOW IT DIDNT BUT I TOOK A BALL POINT PEN AND BENT THE TABS DOWN ON THE FEMALE END AND HOOKED IT UP AND IT WORKED. FOR HOW LONG I DONT KNOW. PROLLY TILL THE NEXT SPEEDBUMP BUT WHATEVER I KNOW WHERE ITS AT NOW
Old Apr 15, 2008 | 10:38 PM
DOHCgarrett t3
Okay, well its acting retarted again and this time im sure its not the harness. im about to run all new speaker wire. does anyone have the wiring diagram or knows where the wires run? coures i didnt get to deep into it cause i was doing it at work and had to actualy work. anyhow. i havent checked the black connection.
it happend when i powerwashed the engine bay so im confued as to if it was the cause of it not working again.
Old Apr 16, 2008 | 03:57 PM
DOHCgarrett t3
anyone?
