no pcv valve (problem solved: new gasket and pcv valve)
Old Apr 11, 2008 | 08:51 PM
fsu182's Avatar
fsu182
Default RE: damnit
yeah. as long as the piece i broke didnt have anything other than hose. i just put another hose over it where i broke it.
Old Apr 11, 2008 | 08:54 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: damnit
Well if you got smoke coming out ur exhuast something is burning thats not suppost to be. Like coolant or oil.
Old Apr 11, 2008 | 08:57 PM
fsu182's Avatar
fsu182
Default RE: damnit
yeah and since its thick white sweet smelling smoke im going with coolant. i think i broke the "valve" part off of my pcv valve. i think by just replacing it with hose that i screwed my idle up. as far as burning crap - maybe its traveling through the pcv area as well. all i know is im getting a new valve cover gasket and pcv valve tomorrow.
Old Apr 11, 2008 | 09:01 PM
I_Ride_Neon
Default RE: damnit
I got used ones if you need. I know they work and work well.
Old Apr 11, 2008 | 09:08 PM
fsu182's Avatar
fsu182
Default RE: damnit
do you have to powder coat a valve cover or can you just use high heat paint?
Old Apr 11, 2008 | 09:38 PM
I_Ride_Neon
Default RE: damnit
powder coated. U like that?
Old Apr 11, 2008 | 10:42 PM
fsu182's Avatar
fsu182
Default RE: damnit
i like what?
Old Apr 11, 2008 | 10:51 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: damnit
no way in hell you can have coolant comming out bettween the valvecover and the head?? did i read that right?sounds like a cracked head. yeah like he said check the oil for water. and you said you drove it a bit i would check the plugs to see if it is fowled because of the water comming out of the tailpipe. even though a few drips is normal happens a lot more when its cold out though of course.
I suppose you could use high temp paint but powdwer coating last a hell of a lot longer
Old Apr 12, 2008 | 11:13 AM
fsu182's Avatar
fsu182
Default RE: damnit
im really hoping im somehow mistaking oil for coolant. as dumb as that would be.
1. will oil burn as white smoke?
2. will oil travel through my pcv valve hose if the pcv valve is missing and its just an open tube?
3. how is the best way to install a valve cover and gasket set? (i dont think the cover gasket will fit insite the channel on the cover and stay while you install it.
Old Apr 12, 2008 | 11:24 AM
bone33's Avatar
bone33
Default RE: damnit
ORIGINAL: fsu182
1..... it can
2.... yes. PCV stands for positive crankcase ventilation. the ball in there is a check valve to keep oil in the engine.
3....put a littlegrease or silicone lube or even permatexin the channel, put the gasket in, then install.
