My weekend... 2.4 swap included...
Old Apr 15, 2008 | 11:01 AM
  #21
mulletman11's Avatar
mulletman11
Default RE: My weekend... 2.4 swap included...
ORIGINAL: das2123
Power is the same....torque is different
i thought the 2.4s, at least from a stratus has like 18 or 20 more hp, plus an *** load more torque
Old Apr 15, 2008 | 11:11 AM
  #22
das2123's Avatar
das2123
DOHC 2.4 HP is ~150....torque is ~160 ft/lbs.
Old Apr 15, 2008 | 11:21 AM
  #23
mulletman11
wat kind of 2.4 are we talking about
cause all over the net, ive seen ratings for a 1st gen stratus as being about 168-171hp and like 210-215lb/torque
wats up?
Old Apr 15, 2008 | 11:27 AM
  #24
das2123's Avatar
das2123
1999 Dodge Stratus Features:
-2,429 cc 2.4 liters 4 in-line front transverse engine with 87.5 mm bore, 101 mm stroke, 9.4 compression ratio, cast iron block, light alloy head, double overhead cam and four valves per cylinder
-Unleaded fuel
-Fuel economy EPA highway (l/100km): 7.8
-Multi-point injection fuel system
-61 liter fuel tank
-Power: 112 kW , 150 HP @ 5,200 rpm; 167 ft lb , 167 Nm @ 4,000 rpm
Old Apr 15, 2008 | 11:30 AM
  #25
mulletman11
^^thats from internetautoguide.com, correct?
im at work, but i have links to other sites on my home computer
lemme see if i can find them
Old Apr 15, 2008 | 11:33 AM
  #26
mulletman11
im an idiot
these are the specs for the turbo stratus i was quoting, sorry das
from wikipedia, no the most credible, but good
A turbocharged version of the Stratus was sold in Mexico, with the 2.4L DOHC 4-cylinder engine and a 4-speed automatic transmission with AutoStick. This car had 168 hp (125kW) at 5200 rpm and 216lb·ft (293N·m) of torque at 2200 rpm.
Old Apr 15, 2008 | 11:34 AM
  #27
das2123's Avatar
das2123
http://www.autobuyguide.com/1999/12-...ons/index.html
Old Apr 15, 2008 | 11:37 AM
  #28
das2123's Avatar
das2123
That makes more sense.
Old Apr 15, 2008 | 11:50 AM
  #29
mulletman11
thats ****ty for a turbo
only 18hp gain? and less than 40 torque?
little baby turbo
Old Apr 15, 2008 | 12:52 PM
  #30
boxerjl2's Avatar
boxerjl2
thats **** for a turbo
little baby turbo
you have to remember though thats on factory Psi i do believe which is like 3-4 or something like that probably
well everything is coming together i got the altenator belt today the water inlet O Ring is comeing in tomorrow.. only thing is i cant find a flange for my header i took it to the exhaust shops and they said they dont have one i took it to Napa and the closest thing they could find is for a 3.0 chrysler vehicle so i bought it and ill find out friday if its the correct size[:@]
im getting so anxious to drive it im just gonna weld the down pipe to the header
