Brakes
If no booster then pdal would be hard with no assist, ala engine off. So Either the master is bad or you still have aire in the system somewhere.
So you just dropped pads and rotors???
Do you have ABS???
If so you may have to bleed that as well.
How are you bleed the system? Check the rear wheel cylinders for leaks as well.
Do you have ABS???
