removing the bumper thingy
Old Apr 16, 2008 | 02:28 PM
boxerjl2's Avatar
boxerjl2
Default removing the bumper thingy
ok right behind the bumper there is a big chunk of metal how much does it weigh and how hard is it to remove??
Old Apr 16, 2008 | 02:31 PM
12 volt's Avatar
12 volt
Default RE: removing the bumper thingy
its there to protect you, so is the syrofoam.
i wouldnt remove it
Old Apr 16, 2008 | 02:47 PM
mulletman11's Avatar
mulletman11
its called a bumper bracket
it is just i think about 6 bolts, 2 top 4 underside
it weighs bout 35 40 lbs and can very easily be removed
but, as 12volt says
it is there to fold in an accidnent, so you dont
this will save ur life, so think twice b4 removing it
Old Apr 16, 2008 | 08:16 PM
95to96transplantneon's Avatar
1st off... watch this vidio josh...
http://youtube.com/watch?v=mciUK50JPFk
2nd think of how much worse it will be if the one bar that is designed to save you is missing...
Old Apr 16, 2008 | 09:12 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
suppose you could remove it, however you would have to replace it with someting comparable to its strength. but finding something would be the hard part unless you know a good fabracator.
other than that i think it is illegal to remove since it is part of a safety measure
Old Apr 16, 2008 | 10:27 PM
vipersforsale's Avatar
vipersforsale
the oem bumper reinforcement piece weighs almost 3 times as much as most of the aftermarket ones... so instead of removing it totally at least take it off and go buy a replacement part. You will save some weight and still be protected far better than nothing. And besides it is what holds your front bumper in shape, without it it will sag and you'll probly end up driving over it one day on the freeway when it decides to finally let go.
Old Apr 16, 2008 | 10:33 PM
DOHCgarrett t3
^X2
Old Apr 16, 2008 | 10:34 PM
oh by the way some insurance companys if you do get into a wreck will not cover you if the factory bumper (thats what its called the bumper... the plastic part the covers it is a bumper cover...) is missing they will drop your insurance plan...
lots of turbo guys and guys concerned about weight will just take a 3 inche hole drill and punch out a bunch of holes across the bumper
Old Apr 16, 2008 | 10:56 PM
das2123's Avatar
das2123
ORIGINAL: mulletman11
No, actually thats called your bumper. The plastic part you remove is your bumper cover or fascia.
Easy to remove...got a replacement one from a junkyard for about $10.
