started a parts list what am i missing???
Old Apr 8, 2008 | 02:04 AM
r3v0l7's Avatar
r3v0l7
Default started a parts list what am i missing???
AF/X Computer, 97-99 DOHC, street/strip, Manual Dodge Neon-----$540.00
AF/X 55mm bored Throttle Body 2.0------------ --------------------$199.95
Accel Fuel Injectors set of 4 (40lbs) bosch injector plug kit----------$310.00
95-99 Neon Stage 3 Axle Hub Combo-----------------------------------$799.95
BIG BREAK KIT------------------------------------------------------$1200.00
Griffin Radiator 95-99 Dodge Neon with fan------------------------------$436.95
Radiator hose's---------------------------------------------------------$22.00
Crate Motor Long Block 2.2 Stroker------------------------------------$5,449.95
Garrett GT 35R dual BB Turbo---------------------------------------$1,499.00
Crane Firewire 8.5mm DOHC plug wire set --------------------------------$49.95
Ignition Coil by Screamin Demon(Late flat pin style connectors)------$74.95
Suspension Techniques Sway Bar Set Dodge Neon ------------------$329.95
Vogtland Coil Over Suspenstion Set for Neon 1995-99------------$1,099.95
Hurst short Shifter--------------------------------------------------$176.00
SPEC Stage 3 non Modular Clutch Kit (Steel)------------------------$409.95
Apexi Turbo Timer--------------------------------------------------$109.95
Blow Off Valve Type H-RFL (BOV-RFL)-----------------------------$159.95
TurboNetics Variable Boost Controller 0-50 PSi---------------------$79.95
Indy/Howell DOHC Intake Manifold ---------------------------------$495.00
NEON T3 TURBO MANIFOLD 420A-------------------------------------$150.00
Budget Intercooler----------------------------------------------------$299.00
Phantom Grip EXTREME lsd---------------------------------------------$349.00
turbo pipeing-------------------------------------------------------------$250.00
grand total-------------------------------------------------------------$12,345.00
and add on 1500.00 for plugs, oil, oil pan, bushings,and small bs ------$13,845.00
what am i missing??? house goes up for sale may 7th and get money form bad accident in 45 days going to build the bride of frankenstein here in the next 6 months...... depending on shipping times dealing with howell automotice yay
Old Apr 8, 2008 | 02:40 AM
fsu182's Avatar
fsu182
Default RE: started a parts list what am i missing???
short throw shifter from maddogsts.com would be cheaper and shorter.
fuel pump?
howell will probably make you wait 2-3 months for your engine
Old Apr 8, 2008 | 03:00 AM
ryleynoyes's Avatar
ryleynoyes
i would do MS (megasquirt) instead of AF/X Computer
Old Apr 8, 2008 | 09:11 AM
spudsterier's Avatar
spudsterier
you cant run the af/f computer with a turbo....so you can knock that off the list
you will need some kind of fuel system
otherwsie, there is plenty of other stuff you can throw on that list
Old Apr 8, 2008 | 01:48 PM
ryleynoyes's Avatar
ryleynoyes
i have 3 (yes 3) 255 lph forgot the name... the GOOD ones... walboro fuel pumps
i need to keep one for myself however
plus a stock srt-4 one
i would also add an msd ignition (msd on modern performance) and i like the matching msd coil, instead of the screamin demon, unless the screamin demon is better in some way that i'm not aware of?
Old Apr 8, 2008 | 02:10 PM
sparky3009's Avatar
sparky3009
Dunno if you are willing to switch turbos, but personally I would use the gtrs turbo.... (Garrett gt28rs).
It's what all the euro guys throw on the vw/audi 1.8t and 2.0t engines, and it's ideal for this engine size. The gt35 series probably wouldn't spool til about 3,000 R's because the inlet is too big. Who knows though, it's up to you. Depends on what sort of numbers your planning on pushing out of that beast.
Old Apr 8, 2008 | 07:56 PM
95to96transplantneon's Avatar
If you are serious about this build...
you WILL Megasquirt the car...
you WILL give up on the 2.2 stroker motor and call darrell ***'s racing and have them build you a 2.6 stroker motor for just a little more then the 2.2.. THEN the gt35R will do just fine... it will kick on alot sooner but allow you to stay out of boost if you want...
Old Apr 8, 2008 | 08:00 PM
spudsterier
the screamin demon coil is actually an upgraded coil...unlike the MSD which is just a stock coil thats painted red....basically
Old Apr 10, 2008 | 11:12 PM
r3v0l7's Avatar
r3v0l7
i am serious about this build. and can i say HOLY SNAP ON BATMAN 221.285mph neon thats the number im looking for lol. im looking to build a highway hell raiser. i probly should of included the parts on the car as it sits lol. 255lph walboro fuel pump bigger fuel rail idk what brand, iceman intake, ground kit, so really nothing lol. all items where very help full i deffently have to give darrell ***'s racing a call and se what they want for one. i hope they dont charge too much more then howell does, and thats going to be an srt4 motor i didnt want to get a srt4 i wanted to kinda stay away from the srt4 i bought a first gen. because i grew up with this car.. 1g ne way,
Old Apr 11, 2008 | 08:46 AM
das2123's Avatar
das2123
I would go with a C&R Radiator...
http://www.crracing.com/
