[ol][*]Pull out the fog light/rear defogger panel[*]Cut the violet with white tracer wire, leaving as much as possible attached to the connector for the fog light switch.[*]Tape and tie the free end of the violet with white where it comes out of the harness. You don't want this shorting on anything![*]Strip the free end of the violet with white wire that's still connected to the fog light switch connector.[*]Strip a small section of the white wire that comes from the rear defog switch. DO NOT cut this wire, strip a section to make a splice. This is the third wire from the top.[*]Connect the stripped end of the violet with white wire to the white wire. Wrap tightly and solder. Tape and tie to prevent shorts.[/ol]
no...
the defogger is still just a defogger, but it will alow you to turn on the fog lights without the headlights....
that is how 1 of my old blue r/t's was wired up
