ohoh help fast?
Old Apr 19, 2008 | 09:09 PM
12 volt's Avatar
12 volt
Default RE: ohoh help fast?
ORIGINAL: das2123
what was it?
should be within 15% of 190, right?
Old Apr 19, 2008 | 09:17 PM
das2123's Avatar
das2123
ORIGINAL: I_Ride_Neon
Well not before i boosted.
Not a great idea
ORIGINAL: 12 volt
ORIGINAL: das2123
what was it?
10-15% of each other, but no lower than ~150 or so. You dont want one cylinder at 160 and another at 205.
Old Apr 19, 2008 | 10:18 PM
I_Ride_Neon's Avatar
I_Ride_Neon
they were all about 170 give or take 5.
Old Apr 19, 2008 | 11:38 PM
95to96transplantneon's Avatar
i would stick around 10% hell 5% if you can...
Old Apr 20, 2008 | 12:51 AM
I_Ride_Neon
I just read that the 95 manifold requires modding to work on 96. Well i didnt mod it and I used it on my 96. Could that cause a problem? What modding needs to be done?
Old Apr 20, 2008 | 08:30 PM
I_Ride_Neon
Well the pistons and head look fine. I think it was the head gasket?
Old Apr 20, 2008 | 08:36 PM
12 volt's Avatar
12 volt
did you pull the #1 and check the ring lands
Old Apr 20, 2008 | 08:46 PM
I_Ride_Neon
No but the side wall is great and the piston moves up and down fine. Nothing in the oil pan. One of the head bolts wasnt very tight. It came off easy. Which is weird. Engine looks great. I will just get the head done and throw it back on for now. I will build my other engine with dohcs pistons and just drop it it some day.
