atx tb with or without c/control
Old Apr 25, 2008 | 12:05 AM
JDAWG901's Avatar
JDAWG901
Default atx tb with or without c/control
i got my atx tb but i need to know my r/t has c/control should i have gotten a tb off an atx with c/control or does it matter and what should i do with the c/control cable?
Old Apr 25, 2008 | 09:07 AM
JDAWG901's Avatar
JDAWG901
Default RE: atx tb with or without c/control
also should i have gotten 1 off a98 same as mine
Old Apr 25, 2008 | 09:35 AM
spudsterier's Avatar
spudsterier
if you use the cruise control, then you should have gotten a cruise control TB
a belive the 95's used a different style CC actuator that had a clip rather then the wire
Old Apr 25, 2008 | 09:42 AM
JDAWG901's Avatar
JDAWG901
i dont use the cc at all i do most of my driving in the city .so it shouldnt hurt disconnecting the cc
Old Apr 25, 2008 | 01:14 PM
spudsterier
you could always just remove the CC actuator and plug the vaccum line...then it will also clear a little room in the engine compartment
Old Apr 25, 2008 | 01:47 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
i thought it didnt matter? just have to swap the shaft?
Old Apr 25, 2008 | 02:46 PM
12 volt's Avatar
12 volt
ORIGINAL: DOHCgarrett t3
im petty sure you would have to mod the shaft for the butterfly to fit. something like the jeep TB http://www.geocities.com/lover232/Enjoy.html
Old Apr 26, 2008 | 12:32 AM
JDAWG901's Avatar
JDAWG901
i just removed the cc acu and no problems . if only i could get rid of those pesky cc buttons maybe new srt wheel
Old Apr 26, 2008 | 04:18 PM
spudsterier
you could also just find a neon in a junk yard that doesnt have cruise control andget the button block off plates from it
