rear drum brakes..
Old May 1, 2008 | 09:59 PM
Neon_Freak's Avatar
Neon_Freak
Default rear drum brakes..
How hard is it to change everything in the back??? im talkn about the brake shoes and everything. all new springs and that stuff. ppl told me i can mess stuff up and the break will lock up. i never did drum brakes just the front.. my break shoes r completly gone and some parts fell out. i have a guy that can do it. just thot i could save 20 bucks. and i have a haynes manual also but that looks realy hard and dont look like my brake setup
Old May 2, 2008 | 10:09 AM
das2123's Avatar
das2123
Default RE: rear drum brakes..
It's not real hard, but it can be very tedious and it will test your patience.
Old May 2, 2008 | 10:19 AM
sparky3009's Avatar
sparky3009
Like das said... its easy to do, it just gets really frustrating if your uncoordinated or havent done it and don't know exactly how.
Old May 2, 2008 | 11:51 AM
Neon_Freak's Avatar
Neon_Freak
ok i was lookn at it last night and it looks like i would just get frusterated with it so im just goin to take it to the guy i know...
Old May 2, 2008 | 12:11 PM
sparky3009's Avatar
sparky3009
If they've been messed with before, there should be a rubber insert on the backside of the drum, then just get screwdriver to lift up the lock-bar, and another flathead to rotate the thing to turn down the brake. Them the outter cover will just come off with a little pulling. I did it on mine, and it's a minnesota car with 230,xxx miles, so they had quite a bit of rust on them too.
Old May 2, 2008 | 12:18 PM
Neon_Freak's Avatar
Neon_Freak
this r the brakes that cam with the car in 96 never been changed.. or it looks t hat way
Old May 2, 2008 | 12:33 PM
sparky3009's Avatar
sparky3009
Then you just have to punch out a little slot. It looks like it has tin-foil over it. It's an easier job than you would think, you just have to know how to do it because your kinda taking the cover off blindly.
Old May 2, 2008 | 12:42 PM
Neon_Freak's Avatar
Neon_Freak
ok
Old May 3, 2008 | 04:17 PM
Neon_Freak's Avatar
Neon_Freak
looks like im goin to have to replace everything now.. []so i have brakes now but it goes all the way to the floor.. im trying to figure out how im goin to block off the back driver side brake bcuz its all apart. well i have alot to get done now my list keeps on getn bigger everyweek.
Old May 3, 2008 | 04:58 PM
Neon_Freak's Avatar
Neon_Freak
how can i temperaryblock off my driver side rear brake??? i need a answer asap ok thanks
