update and question
Old May 3, 2008 | 01:06 AM
ryleynoyes's Avatar
ryleynoyes
Default update and question
well, i got the whole front suspension done (new energy suspension bushings, new stage 3 axles, suspension techniques sway bar, mopar hi rate springs, koni adjustables, hawk brake pads, baer slotted/drilled rotors) and all i can say, from the amount of lift at one corner, holy crap! i can lift under the control arm on one side, and lift until the normal ride height level, and the OTHER FRONT CORNER will lift to within 3 inches of it! i know the stock suspension didn't do that!
now for my question
after i got this all put together, i took it for a small test drive
i got halfway down my dad's driveway, about 100 yards, and about 10mph, and the car started jumping/jerking around
so i went back and double checked my wheel bolts and stuff, all bolts except the new hub bolts, as i have the cotter pin in it
went back out, and it did the same thing, so i thought, maybe it's just my dad's driveway is bumpy with my tight suspension, and got on the road
still did it
so my question is, what would cause it to be jumpy/bumpy like that? i'm thinking really bad alignment wouldn't be able to give me all these symptoms, as it did it on gravel and tar. maybe misaligned hubs?
Old May 3, 2008 | 01:08 AM
sparky3009's Avatar
sparky3009
Default RE: update and question
Do the wheels spin freely? Do they wobble at all?
Old May 3, 2008 | 01:13 AM
ryleynoyes's Avatar
ryleynoyes
i'll check tomorrow
i didn't get a good chance to check it out on wednesday, as it was after midnight already
95to96transplantneon's Avatar
your going to need to get a alignment asap... all these new things compleatly change the projectory of everything in your suspention... dont drive it flatbed it...
Old May 3, 2008 | 01:16 AM
ryleynoyes's Avatar
ryleynoyes
how far is too far to drive it?
and what if i just drive REALLY slowly?
nearest alignment shop that i'd go to is about 20 mile drive
Old May 3, 2008 | 01:29 AM
does it bounce on a flat surface???
Old May 3, 2008 | 01:32 AM
ryleynoyes's Avatar
ryleynoyes
do you mean while driving, or sitting?
while driving, it feels like a REALLY badly balanced tire, or flat spot or something similar to that (which it could possibly be, as i had the front end on jack stands for about 2 months, and the rear on the tires, without moving it at all)
Old May 3, 2008 | 01:35 AM
mulletman11's Avatar
mulletman11
u put those eyelids on?
Old May 3, 2008 | 01:39 AM
its probally the tires that sat on the ground for so long
Old May 3, 2008 | 01:40 AM
ryleynoyes's Avatar
ryleynoyes
any way to clear that off without driving it? i did move it from original position, so it shouldn't be on those spots right now
