2.4 motor mounts
Old May 7, 2008 | 10:34 PM
Chagoracing's Avatar
Chagoracing
Default RE: 2.4 motor mounts
yes I ready reed
Im searching the ptPS bracket and the alternator brackets
I will make my own munt adapter
I dont change the harness
and....
Old May 8, 2008 | 12:51 AM
95to96transplantneon's Avatar
Im not trying to be mean but many people have tried to make there own mount adapter and failed horribly... make sure its solid and by solid i mean 1 inch thick like the ones you buy...
Are you using the pt water outlet neck???
if not the lower radiator hose is going to rub horribly and make a hole in the hose about 2 times a month...
Old May 8, 2008 | 02:13 AM
Chagoracing
Yes Im searching the neck to
and you dont know waht size is exactly the adapter?
THANK YOU for your help
Old May 8, 2008 | 12:42 PM
I can pm boxer and see if he can messure it up for ya... I'll make sure that you get the measurements and a pic explaining where the measurements are...
