grinds into second
Old May 7, 2008 | 12:05 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default grinds into second
need help trying to figure out why trans grinds while going into second gear. I always have the cluch fully enguaged but everytime it still grinds into second. wtf is going on
Old May 7, 2008 | 01:01 AM
neonracer1010's Avatar
neonracer1010
Default RE: grinds into second
u cant drive
cant find em grind em
but seriously the shifther arms mite need to be lined up
Old May 7, 2008 | 01:15 AM
DOHCgarrett t3
how do i do that?
Old May 7, 2008 | 02:13 AM
DNeon's Avatar
DNeon
does it only grind on 2nd?? did you check your bushings?
Old May 7, 2008 | 02:14 AM
DOHCgarrett t3
grinds only going into second
Old May 7, 2008 | 03:47 AM
JackMehoffer69's Avatar
JackMehoffer69
Your transmission snycros might be toast or worn.
Old May 7, 2008 | 09:56 AM
spp's Avatar
spp
yea i agree the snycros might done second gear is the most gear u use. either that the shift fork might be messed up. i had the same prob and it was my shift fork
Old May 7, 2008 | 10:05 PM
DOHCgarrett t3
how do i fix the syncros and how do i fix the fork and how many diffrent forks are there or do they have the same name for the same fork.
the reason i am asking is because i did a search and i found several names with fork in it. it was earlyer today and i have forgot the other names
Old May 8, 2008 | 01:01 AM
95to96transplantneon's Avatar
ORIGINAL: DOHCgarrett t3
Ok you dont fix syncros you replace them... and when you replace them you replace everything due to everything basicly being one pieace... and a rebuild kit is more expensive then a good used tranny... sorry....
Old May 8, 2008 | 01:30 AM
neonracer1010
but the fork is cheap ahha
